Locking axles recommendations?
Bellime
Keith
2022 Ford Bronco
Ok, so my miss, but I want to plan to correct the fact that I didn’t get the lockers when I bought my flying brick. I don’t do a lot of 4 wheeling, but I do a fair amount of logging on my property in Montana. This will be a many year project due to a fixed budget. Some opinions and technical advice from the Bronco group would be appreciated.
First, I want to stay close to OEM parts and don’t need this for the gear upgrades. I am thinking the base lockers from Ford. Can I just do the rear axle without doing the front at the same time?
I am also going to order the full wiring harness for the dash buttons for OEM functionality.
Big Boss
Outer Heaven
Bronco Big Bend
From my understanding, if you do a drop in locker axle assembly from Ford, you would at minimum also need to re gear the front end to match the ratio.
If you didn't want to tear open the front end, you could just do an air locker or eaton e locker and then would need a new 3.73 ring gear set to complete the install
Felix808
SRV CA
Yes, the lockers are independent of each other & will replace the differentials. All you will need is a switchable 12v to turn them on & off for electric lockers. I prefer the electric over an air locker like the Already Broken (ARB) because they tend to be more reliable
Bellime
Bellime
Keith
2022 Ford Bronco
I am reading that the base OEM rear lockers are 4.27 ratio, but I don’t see any reference to the front.
Rspayde
North Ga
2022 C/O Black Diamond
  • Like
Reactions: LCW
Rspayde
North Ga
If I am correct ford recently released the full axel as well as the wiring needed to add the switch. Multiple different gearing options as well.
https://performanceparts.ford.com/part/M-4000-446B
Yeah it is all up there. Honestly makes for a pretty straight forward upgrade.
Would need to match the front gearing still and also need to purchase the recalibration tool.
RagnarKon
Ford Bronco, Escape, Focus
The front and rear axle ratio have to match.
Factory options:
  • 4.27 w/ rear locker
    • Optional on Big Bend & Outer Banks with the automatic transmission
  • 4.46 w/ rear locker
    • Standard on Black Diamond
    • Optional on Big Bend & Outer Banks on the manual transmission
  • 4.46 w/ front & rear locker
    • Standard on Badlands with the automatic transmission
  • 4.70 w/ front & rear locker
    • Standard on Badlands with the manual transmission
    • Standard with the Sasquatch package
And Ford Performance options:
  • 4.88 w/ front & rear locker
  • 5.13 w/ front & rear locker
  • 5.38 w/ front & rear locker
Bellime
Bellime
Keith
2022 Ford Bronco
Can’t I get the base 4.27 rear locking axle from Ford instead of the upgrade 4.46?
Unless you have the OBX with the 3.7 ratio, you can just buy the rear end that matches your existing ratio with a locker.
The ford options @RagnarKon listed are your best bet - unless you can find an acceptable takeoff. It will replace your entire rear end and are all you really need.
You can wire it up to an upfitter (either oem switches or aftermarket ones) to activate. Goat modes won’t automatically activate it, but imo that’s ok because you rarely want lockers engaging without your specific intent anyway.
If you do not change the ratio - there is nothing to reprogram or adjust in the computers.
If you want to upgrade your ratio to something lower geared (higher ratio) at the same time, or you have the 3.7, then you would also have to do the front. The front would also will require new separate axles (the rear end will include everything you need apart from a switch)
swooshdave
Portland, Oregon
Mustang
Are you dragging the logs out with the Bronco or just getting to the cutting areas?
RagnarKon
There are two upgrade paths depending on your transmission.
Manual Transmission
You simply need to buy a 4.46 rear locking axle and the associated wiring kit.
Automatic Transmission
If you currently have no locking axle, that means you have a 3.73 axle ratio. So you will need to replace BOTH the rear axle and the front drive unit. Since you'll have to replace the front drive unit anyway, it makes sense to just re-gear to 4.46 and add a front locker as well.
Parts:
Oldhippie
Barry
Santa Cruz, Calif.
Pretty sure ya can buy a e-locker for the rear that will work with your gear ratio…maybe not from ford…give Yukon a call…but I would go for lower gears, the lower the better, if in there anyway…
lakesinai
Charleston SC
When you upgrade the Non-Sas OBX to a rear locker, yes, it becomes a 4.27 rear end. The front gearing would have to match OEM. I did that.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Your cheapest option is
$600 labor Set-up gear
$200 to wire up switch
$300 3.73 gears + Install Kit
$1000-1500 for the locker
Realistic option,
$1200 for a 4.46 gear m190 front
$2500 for a 4.46 M220 Rear
$1000 labor + switch install(regular not from ford)
The correct way,
$1800 for a 4.71 gear m210 front
$500 for M210 cv axles
$2500 for 4.71 M220 Rear
$700 ProCal
$1000 labor + switches install(regular not from ford)
You are asking a very expensive question. Since your asking how I will assume you aren't doing the labor. Get past the factory integration as ford performance sucks ass and can't help you with any technical issues. If you want factory switches I would charge you per hour. You can watch me pick my nose on the phone after fallowing the instruction and nothing working like it should.
If you want factory integration go trade up at dealer, its cheaper.
