Light Bar Length
Light Bar Length
  • Total voters
Clemitine
Wisconsin
Hi, just recently got a Bronco and was wondering what size lightbar I should put on it. What size light bars are you guys running on your Broncos?
RagnarKon
Ford Bronco, Escape, Focus
Much like @scotman623... 40" here as well.
Also worth noting that 40" fits between the two accessory mounts on top of the A-pillar (same place where the roof rack attaches).
Aman
Aman
Northern NJ
I went with 50". Fits perfectly!
Ford Bronco Light Bar Length img_9049-jpe
Clemitine
Wisconsin
It fitting between the mount points a thing you like about your light bar?
RagnarKon
It's important for compatibility with many roof racks. Effectively means your light bar can fit between the front supports for your roof rack. Or in the case of the @TrailRax rack... you can mount your light bar directly to the roof rack itself.
Ford Bronco Light Bar Length 1687373218817
RimrockPaul
Paul
Rimrock AZ
2021 Ford F250
0" no lightbar. So far the 2 OEM headlights work just fine.
Clemitine
Wisconsin
The roof rack doesn't attach to the mount points?
Aman
Aman
Northern NJ
Looks Great! Do you recomend KC lights?
I love the KC's! The only other one I considered is the Baja Designs XL Linkable kit, but I think the KC's look better than all the rest.
Other bars may put out more light, but I've used this one on high speed night runs, through the trees, and never felt as though I needed more.
I also swapped out two of the covers to match this look I found on the Badass Tents web site. Very happy with my purchase.
Ford Bronco Light Bar Length badass-tents-new-bronco-2-door-short-roof-rack-5
RagnarKon
It does.
And if your light bar fits between the two mounting points, you can mount the light bar itself to the roof rack.
Clemitine
Wisconsin
Why did you pick the 50? Doesn't it mean you can fit a roof rack on now?
Clemitine
Wisconsin
It does.
So a 40 is just something that will fit no matter what
