Rigid 20 inch LED bar light wiring.
Spiderwolf
Mickey
woodstock, GA
2012 Rubicon, 2016 Dodge Challenger RT Scat Pac
So I got a Rigid 20 inch light for the front of my bar on a bodyguard bumper. I know we have the uplifter switches and wires to attach accessory lights and such too. But this light comes with all its own wiring, fuse, relay and on/off switch. I don’t want to have to use all that. Can I attach the light wires ground to ground, hot to one of the hot wires under the hood without using the relay that came with it. Does the Bronco already have the relays built in so I can just wire directly or am I stuck using the lights delays and fuse.
jhruzek
Houston
2022 BRaptor, 2024 BRaptor
How many amps does the bar draw?
Spiderwolf
Mickey
woodstock, GA
It’s a rigid SR series. It says the 20,30,40 and 50 inch SR series all are rated at 15 amps. Not sure how that could. I would think the bigger the light the more amps but that’s what it says.
Ford Bronco Rigid 20 inch LED bar light wiring. IMG_5338
