Maximum Light for the Bronco Raptor: XL Light Bar Setup
MandRautomotive
Mikhail
CA
Hey Bronco6G,
For the Bronco Raptor owners looking for serious auxiliary lighting for trails, desert runs, and back roads after dark, we wanted to share our M&R Automotive 2022+ Bronco Raptor XL Light Bar Kit.
This setup was designed specifically around the Bronco Raptor, giving you significantly more forward lighting while maintaining a clean, vehicle-specific installation. Instead of adapting universal brackets or drilling into the Bronco, the kit uses dedicated mounting hardware designed around the factory Raptor.
A few highlights:
  • Designed specifically for the 2022+ Ford Bronco Raptor
  • XL LED light bar setup for maximum nighttime coverage
  • Combination of long-distance visibility and broad usable lighting
  • Vehicle-specific mounting brackets
  • Bolt-on installation
  • Designed to complement the factory Bronco Raptor front end
  • Built for trails, desert driving, back roads, and other nighttime off-road use
  • Durable construction for off-road conditions
  • Complete mounting hardware included
  • Designed for off-road use
For us, the biggest advantage of the XL setup is the amount of usable visibility it provides when you're moving through completely unlit terrain. On a Bronco Raptor that's already built to cover ground quickly off pavement, having more visibility farther down the trail can make a big difference.
If anyone here is running auxiliary lighting on their Bronco Raptor, we'd be interested to hear what setup you went with. Light bar, ditch lights, fogs—or a combination of all three?
If you have any questions about the XL setup, fitment, installation, or wiring, feel free to ask. We're happy to help!
Ford Bronco Maximum Light for the Bronco Raptor: XL Light Bar Setup 2022+ Ford Bronco Raptor XL 1
Ford Bronco Maximum Light for the Bronco Raptor: XL Light Bar Setup 2022+ Ford Bronco Raptor XL 2
Ford Bronco Maximum Light for the Bronco Raptor: XL Light Bar Setup Discount Banner Bronco6G
G1D1UP
J.
Gilbert, AZ
2024 Ford Bronco Raptor
Too bad that light bar asking for real estate that I've already leased out to my manly man's bull bar. I dig that strong DRL look though. Wish I could make that work. Not sure about the Grover Cleveland price tag!
Ford Bronco Maximum Light for the Bronco Raptor: XL Light Bar Setup 20250916_060849
MandRautomotive
MandRautomotive
Mikhail
CA
Nice ride!
MandRautomotive
MandRautomotive
Mikhail
CA
For anyone considering the M&R Automotive XL Light Bar setup for the 2022+ Ford Bronco Raptor, here’s an install video showing what’s involved in getting the kit mounted and wired up.
It’s a good look at how the XL setup integrates with the Bronco Raptor and what to expect if you’re planning to tackle the installation yourself.
Hope this helps anyone considering the setup or getting ready for the install. Feel free to ask if you have any questions!
