Lets talk Load Range and comfort...
kodiakisland
Arkansas
What is the benefit of a load E tire or F? Y’all are putting 1 ton truck tires on a little SUV (12 ply tires). Why? If you don’t have a good enough reason than put the manufacturer spec tire on it. This horse has been beat to death in the Jeep world for sometime. I just went through this with my old wrangler. There are fewer and fewer load range C tires in 15” for my Jeep. A lot of people have tried load range E and regret it on the Jeeps. I stuck with a C tire and I’m glad I did, rides good and airs down nicely (gives a nice footprint). At some point I might have to switch to a 17” wheel on my Jeep to get enough selection to find a C tire, 15’s are just slowly going away. I’ve read that many E tires won’t even begin to bulge the sidewall until they get down to less than 10 PSI (with a Wrangler sized vehicle). Everyone who is buying F tires isn’t buying them for function but rather for form. You are correct, to each their own. Here is a picture of my tires with 12 PSI, ended up going to 8 later and they were perfect in the dunes. Our Bronco was at 12 PSI with C tires and did fantastic, probably should have went lower with them also. C range is fantastic on and off-road and matched to the weight of our Bronco’s (and Jeeps).
Again, again, etc., run what you like and what works for you. I don't think you genuinely want to know why anyone runs anything other than what you do. The places I go and the things I do, I want thicker, heavier construction. At proper PSI, they work great on and off road. If you only want C, great. Really. Stick to what you know.
BroncoBarn
Illinois
2002 Wrangler
I’m not being a smarty pants, but where do you go that a 12 ply tire works better or is needed. I’m being serious, I want to be prepared.
AZ_Liberty
2007 Expedition
Because manufacturer tires are soft squishy garbage. They puncture the first time you drive over a twig or cactus spine. Absolute trash.
A truck should have truck tires. I've got E rated tires on my 2WD Expedition.
Lucky13!
Lucky13!
jeff
Charlotte
Ford Flex
My Bronco came pre-modified from the dealership to the specifications of the original reservation holder when they ordered. It is a 2 door Badlands with Sasquatch, 2.3/auto, lux, and leather. Per the customer request they added a 1” leveling kit, Ford Performance hood scoop and fender flares, and most importantly for this discussion, 35/12.50x20 Nitto Ridge Grappler (load range E) on 20x10 Fuel Blitz wheels. That customer backed out before delivery and I picked up my Bronco from the dealership back in March.
I put 5000 miles on it since I got it. Fuel mileage was good -19.8 lifetime, acceleration and braking were fine, road noise was good, and the whole package made my Bronco unique. The ride however was really stiff, the wheels/tires really heavy (115 pounds per,) and the position of the spare on the gate (pretty far out with the wheel offset) combined with the weight caused me some concern. Despite lowering the pressures down to 32 per tire I still couldn’t take the edge off due to the 10 ply construction and low sidewall. I used extreme caution off road as well as it seemed jarring enough I was concerned for longevity of components.
For these reasons over the weekend I changed wheels and tires from those described above to the 17x9 Fuel Blitz (because I really liked that wheel on the Bronco when I bought it) and a 315/70x17 BFG KO2 (load range C)
I’ve had the KO2 on 3 different Raptors in this size and 2 different Jeeps in a 285 series and they’ve always done extremely well. They’ve worn well, last long (40,000+ on all vehicles,) gotten me through all on/off road situations I’ve encountered, and rode beautifully. Words could not describe the difference they made to the Bronco. The 10/12 ply range E/F on a small, light weight vehicle are overkill in my opinion. But as others have said, go with what’s right for you.
If you decide you want to try the E, let me know. I’ve got a great set for sale now!
Great info, thanks for the reply.
kodiakisland
Arkansas
First off, ply ratings are not actual plies, so no one is really driving around on 12 plies anymore. Tire construction in the heavier load rating is usually stronger in most areas, but not necessarily noticeable when you dissect the tire. Some Toyos only differ by 1-3 lbs from C to E rating, but are constructed differently to add strength in certain areas.
So where do I go? Just about everywhere. Usually solo. Usually in remote areas. Usually on unimproved trails. Many old logging skidder trails and decommissioned forest service roads. most full of all kinds of trash that loves to poke holes or slice sidewalls. I've gotten multiple flats at once in remote areas. I don't like walking. Load E tires work when you get the right tire for the application, but isn't that the point? Get what works for YOU.
In May I was in Idaho solo for a week. I saw one other person in a week. Next month I will be in Montana solo for a week and hope to not see anyone while there as well. Almost every other week I'm on trails here solo in areas with no cell coverage.
I use what works for me. I've tried a lot of stuff myself and determined what I do and do not want and what fits my use. I encourage people to use what works for them.
BroncoBarn
Illinois
2002 Wrangler
Cool!
BroncoBarn
Illinois
2002 Wrangler
Which tires are soft squishy garbage? BFG KO2’s?
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
The Territories. Too light, quite a few have been punctured already.
I did puncture my MTs on my very first gravel truck trail. Certainly didn't expect to need to airdown on a trail like that one. I've since dropped road pressure down to 36ish, and am much happier there. I've dropped them down to 18 or so to cruise through the sand wash and do some rock crawling without issue. I will run them until they're fried, then probably go to K02.
ctandc
VA
'22/23 Bronco, 96 EB Bronco
The main difference in rice harshness you experienced was a 20” tire vs a 17” tire. Look at how much sidewall you have now vs the 20’s.
Increasing load range ( alone ) on a tire does not increase the harshness of the ride.
Tire construction varies per manufacturer and tire model etc.
I can tell you that MANY of the trucks, Jeeps and now Broncos you see riding around that have larger tires and wheels are likely riding around with load range D and E tires overinflated for the application.
I had preordered the tires for our 22 BB. The day we picked it up we were at Discount Tire getting the new wheels / tires mounted.
I requested they set pressure at 32psi. (E rated). The manager came out and spoke with me and relayed how many times they installed upgraded tire / wheels or addressed drive ability concerns with installs and many times the air pressure was way too high. He had a laminated chart with guidelines for Load Range vs GVW vs PSI because of this. He said people routinely ignored him and the chart, people who didn’t know what load range was, but were quoting a friend or something they read on the internet.
equitasforall
Out of the country until late 2025
2021 Bronco Badlands
I agree completely and had even mentioned that in my post where I referenced not being able to soften it up due to a combination of construction and low sidewall, which is one of the biggest reasons I changed them out. Was the right move for me, may not be the right one for others. For me I never would have started with a 20 on there but as the dealership had already installed them they weren’t going to swap them for another set. I gave them a shot and moved on.
Mortonm
Canada
2022 Ford Bronco Black Diamond
I dont have my Bronco yet but have run 3 different sets of 235 85 R16 (load range E) on two Xterras, which are lighter than the bronco.
No issues at all with ride quality.
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
One reason it’s hard to find a load range C in certain sizes. Or the price is $100 more per tire. On the fuel tires (dealer choice not ours) they don’t seem like an F or even E they ride softer for sure. I’m also not running 80psi in them. And the sidewall seems pretty flexible. These are also an off road mud tire. Not an AT that might make some of the difference.
Trino351c
2022 Bronco, John Deere Tractor, Snowshoes
LOAD RANGE AND PLY RATING
Tire experts use a few different classifications to describe a tire’s ability to hold air pressure and carry weight. Load range is one of these and describes how much weight a tire can carry. It’s listed on the sidewall of your tire, represented by a letter.
This letter tire load rating gives you a comparative idea of the tire’s toughness; helping you understand how much air your tire can hold, how much weight it can carry and a relative measure of the tire’s durability. Tires with a higher load range can carry heavier loads.
Load range is based on an older measurement called ply rating. All tires are constructed of rubber and cord layers referred to as "plies". Historically, more plies gave a tire a larger load carrying capacity, so manufacturers would count the plies and use this number to denote this measurement.
However, modern tire construction uses fewer, stronger plies. Therefore, load range simply defines the tire’s toughness and maximum allowable air pressure, as opposed to specific information about the actual plies being used. For example, a "C" load range indicates that a tire is equivalent to a 6-ply construction tire. This tire isn’t actually built with 6 plies, but rather one or two plies of equivalent strength.
The load range is indicated by a letter on your sidewall but it is also accompanied by a number to indicate the max air pressure the tire can take. Using the above "C" example, you may see a "C1" or "C2". "C1" and "C2" are both 6 ply rated, but C1 has a max air pressure of 50 PSI and C2 has a max air pressure of 35 PSI. This holds true for other ply ratings too.
It’s best to have a tire expert make sure your tires are properly rated to support the weight of your vehicle.
Check our load range chart, which notes the ply rating and the max load carrying air pressure.
Load Range and Ply Rating
Load RangePly RatingMax Load Carrying Air Pressure
Standard Load (SL)4@ 36 PSI
Extra Load (XL)4@ 42 PSI
C16@ 50 PSI
C26@ 35 PSI
D18@ 65 PSI
D28@ 50 PSI
E110@ 80 PSI
E210@ 65 PSI
F112@ 95 PSI
G14@ 110 PSI
LOAD INDEX AND LOAD CARRYING CAPACITY
Load index is another way to further describe a tire’s carrying capacity. The load index explicitly indicates the max load a tire can carry. To find your tire’s carrying capacity, look for the load index number on the sidewall. Load index is a more precise method of measurement than load range which focuses mostly on construction.
The load index number indicates a tire’s carrying capacity when inflated to maximum load sustaining pressure. It further explains the tire load range measurement by adding more specifics to the rating.
Find your tire’s load-bearing capacity by checking our load index chart below. Most cars and light trucks have load index values ranging from 70-124.
Load Index and Carrying Capacity
Load IndexCarrying Capacity (lbs)Load IndexCarrying Capacity (lbs)Load IndexCarrying Capacity (lbs)
099504191001764
1102514301011819
2105524411021874
3107534541031929
4110544671041984
5114554811052039
6117564941062094
7120575071072149
8123585201082205
9128595361092271
10132605511102337
11136615671112403
12139625841122469
13143636001132535
14148646171142601
15152656391152679
16157666391162756
17161676771172833
18165686941182910
19171697161192998
20176707391203086
21182717611213197
22187727831223307
23193738051233417
24198748271243527
25204758521253638
26209768821263748
27215779081273858
28220789371283968
29227799631294079
30234809921304189
312408110191314289
322478210471324409
332548310741334541
342608411021344674
352678511351354806
362768611681364938
372828712011375071
382918812351385203
393008912791395357
403099013231405512
413209113561415677
423319213891425842
433429314331436008
443539414771446173
453649515211456393
463759615651466614
473869716091476779
483979816531486844
494089917091497165
1507385
