userdude
userdude
Denton, TX
2023 2dr Badsquatch
Admittedly I didn't click any of the links or watch the video, but I did read your tutorial. Any word on cost? I'm considering the upgrade eventually.
The HOSS 3.0 from Ford will set you back $1600 or so, with a $400 core charge. If you buy it from a dealer you can pick it up, there's no shipping cost. Definitely just keep the HD tie rods, you don't need anything beefier. After that it's tools or whatever. Most people will take this route. If you take it to a mechanic, be prepared to pay for 4-6 hours of their time. Also consider getting the bolts, which may add tens of dollars (Ford is proud of their bolts). It'll need to be programmed, too (see below).
The 74Weld stage 3 rack is a different story. Get the OnX Elite discount, I paid $27 to upgrade and it saved me $400. After shipping and tax, I paid about $5700 for their rack, and it's all ready to go. The bolts, if you want to replace those, that's a little extra. You don't need a 3.0 rack, it comes with one. 74Weld's are already programmed. You just have to pay for shipping and install it.
If you have a 3.0 rack, you can get the cheaper Stage 2 rack and have it installed and programmed. I would expect installing it to be $300-500 maybe (totally guessing based on hours?), and programming maybe $300 (you have to have FRDS, which is a cost too). If you have the rack already, this is a reasonable add-on if you want the bomb proof rack option. Note on this one, if the 3.0 rack is on your Bronco, you'll need to remove it to install it into the stage 2 housing.
For me the cheapest thing was to go ahead and buy the 74Weld stage 3 rack. Otherwise, you can just get the HOSS 3.0 rack, return the core and have a fairly reasonable cost once you include getting it programmed.
Tor148
Tor
Cape May Court House, NJ
23 Braptor Bk, 21 FE RR, 15 F250,
I decided couple weeks ago the better part of valor was to spend the cash and upgrade my steering rack. Based on the increasing difficulty of what I'm up to off road, it seemed prudent to get the 74Weld rack.
I huge thank you and shout out to @mpeugeot. It would have been mind boggling to get this done myself. Also props to San Angelo, which is a very nice little town. The Angry Cactus is very tasty. Try the prickly pear margarita. And also, @Bmadda who got me into this in the first place. lol
Tools Used
- Safety glasses (do not omit!)
- Ratcheting strap, for immobilizing the steering wheel (you can also use the seatbelt)
- Impact drill
- Breaker bars
- We used two torque wrenches, one went up to ~190psi
- Ratchet set with extensions, including a 10mm up to 21mm (on the latter I believe that was the biggest...)
- Two larger adjustable crescent wrenches for adjusting the tie rod lengths
- Blue loctite
- Measuring tape or ruler, for installing the tie rod arms, which the outers are slightly longer on the HD set
- Flashlight for tightening the steering column set screw
- Lift and/or ramps or jack stands w/jack (wheel chalks if you're using ramps or jack stands)
- We used a Dremel to cut the boot clamps off
- Hammer and torch to heat/coerce the tie rod seat on the wheel assembly
- (You might consider padding to lay on and knee pads if you're on the ground)
Setup
- 74Weld's rack did not take long to receive. I would've had it in four days if UPS hadn't had a broke down truck.
- Consider, if you are going with 74Weld's rack and you don't have a HOSS 3.0 yet, it could very well be cheaper to just buy their packaged Stage 3. Especially consider at least right now they have an OnX Elite discount that is substantial, as well.
- If you do have a HOSS 3.0 rack already, get the Stage 2 and get it programmed. mpeugeot does them at least in Texas. You might ask him if you're looking for programming.
- The box 74Weld's rack comes in is small enough to fit in the back of my 2dr. The tie rods are not installed, in other words.
- If you don't have a shop manual, consider you'll need to know the torque amounts for most of the bolts you remove, so you can put them back on correctly.
- You can probably do it all yourself, but it's much easier if you have an extra set of hands.
- Start early and budget an extra day. Especially if you don't have a lift you can walk under. Overall I think we spent about 10hrs over two days with some mitigating circumstances.
The Job
- Important: Immobilize the steering wheel from turning FIRST. A slight turn is not bad, but a quarter or half turn can mess up your clock spring, which I hear is a Bad Thing. We used a ratcheting strap, wrapped around the bottom of the steering wheel, then fed under the seat and hooked one end to the headrest post, then ratcheted down. This worked pretty well.
- Watch the 74Weld install video and note that they do not at all show disconnecting the steering column from the rack. Completely omitted, probably because it's hard to show it.
- The order that the bolts are removed and put back matter in making it easier to take care of. The order in the video and reversing the order to reinstall is probably a good starting point.
- Make sure and pay attention to the direction the steering column set screw points. lol Not a big mistake, but if you have slip in your steering, check this screw is too loose or is reversed from how it should be.
- Take the front tires off once you've got it jacked and secured. You see this in the video.
- We took the inner tie rods off the rack while the rack was still in place. I guess you could leave them on, but I don't know how you get the rack out.
- Other than the hassle of breaking the bolts out of their loctitedness, the first big hurdle is getting the tie rods off the wheel. We ended up heating the mount the outer tie rods sit/drop in, hitting the seat with a hammer, then heating some more. They eventually come out but expect they will be wedged in there pretty good.
- Wrangling the HOSS 2.0 steering rack out of it's cozy little spot is a lot of fun! Not really. I have the front lockers, so getting around that is where the snag happened for us. We pushed, pulled, crushed my hand and finger, and eventually wended it around somehow (pull passenger and push up and twist!!!). It was a good feeling when it finally came out.
- Reassembly is much easier than the first time you take this all apart.
- The 74Weld rack is easier to get in. It didn't slide right in, but we didn't really struggle.
- Pay attention to the direction of the steering column clamp bolt. :)
- Measure the lengths of the tie rods when you have them both out. Make sure you compare the left and right side with their matching new tie rods. They should have stickers to designate the left or right side when reinstalling.
- You don't have to loctite every bolt, but make sure and do the big bolts on the frame.
- Make sure and follow the torque requirements listed in the shop manual. There are members on the forum who can help with that.
- When putting the bolts on the front differential, if you have one, note that you'll need to push it up and wrangle it a little to get bolts in place. You may need a jack or otherwise something or someone to help with this part. Also, tightening the bolts down too quickly can make it hard to move it around.
- Note that Ford recommends replacing most of the bolts you remove. You can see the recommendations in this TSB. We did not replace any, although I might replace the steering column clamp bolt eventually.
Post-Install
- Once the rack is installed and connected to the wheels, start the engine to see if you get error messages. If you do and don't know what to do, start a thread.
- Put the wheels back on and then take it out onto a quiet street to see how it performs. Note that measuring the tie rod arms will get you close but you'll need to get an alignment soon.
- Your steering wheel may not be straight. When you get your alignment, they should fix this. I drove 300m with a steering wheel cocked about 1/6 turn driver.
- If you feel slack or anything other than what you felt with your steering before, take it back and investigate. As stated, we put the steering column clamp bolt in backwards and it slipped at first when turning. It was obvious we needed to fix something.
- Try to find a non-busy road that's straight, then steer straight and let go of the wheel, ready to grab the wheel. You should generally drive straight-ish. If it darts to the side or does anything unusual, take it to get an alignment ASAP or back to double check your install is correct and complete. Be safe out there.
- Now get an alignment. Note that if you have lane assist/advanced cruise control, it costs more. I was not able to get an alignment since San Angelo didn't have any working techs or machines at Firestone on Sunday, so I drove it home 280 miles at 57-62mph. It drove like a Jeep at any higher speed, which is to say not a lot of fun.
Final Words
Overall, it was a bit of an ordeal at times and without Mark's friendly help and knowledge (and better physical shape... lol), it would have been challenging. It certainly would've taken a LOT longer and I would've been lucky to get a lot of it right, at least at first. Big thanks again and keep wheelin'!
Great write up, thank you.
You guys want to take a road trip to NJ and help me install mine? I got a lift!!!
Ford Bronco Lessons learned from installing the HOSS 3.0/74Weld steering rack Screenshot_20231101_184343_Email
Mine is sitting on my porch, and I am away for an event. When i get back, its top of the list!!!
nolimits
23 Badlands
Love seeing this post, thank you for sharing. Good tech info and reminds me of the brotherhood when I owned my Jeep. So many times local guys would get together and do installs like this. There is no substitution for that help and knowledge.
Kudos and job well done. 😎
userdude
userdude
Denton, TX
2023 2dr Badsquatch
Congrats!
contented
Karl
Central Fl
BMW M2 Competition
Thanks for the write up. Thinking about doing the exact same thing. Just wanted to make certain it was indeed plug and play with no codes on start up..
mpeugeot
No codes.
userdude
userdude
Denton, TX
2023 2dr Badsquatch
The 74Weld Stage 3 (but not Stage 2) rack is already programmed. The Ford HOSS 3.0 stock rack does NOT come programmed by itself.
shawn6107
Shawn
Tuttle, OK
Ford F250, Ford Expedition Max, Chevy Silverado
Nice write up and congrats on the upgrade! Hope we get to wheel together again sometime soon so I can see that thing in action!
pwaicon
South Lake Tahoe, CA
Ford Bronco Badlands SAS
Thanks for sharing. I ordered both the Stage 3 rack and the portals, the rack should be here in about a week or two. The portals are going to take a little bit longer, hopefully by the end of January they should arrive. In the meantime I am trying to get all the info I can to help the install go as smooth as possible. Once again thanks for the write up and sharing.
userdude
userdude
Denton, TX
2023 2dr Badsquatch
Very cool! I think the portals are still one offs, so that makes sense. It did not take very long for my rack to come in (3 days plus 4 days UPS said "mechanical issues"), so I'm wondering if it's a week or if that means they're building more. They had an order of 100 HOSS 3.0 racks coming in when I bought mine.
pwaicon
Yep, he said they were expecting an order HOSS 3.0 racks this week and would be working on getting them assembled and shipped out.
Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
How is the programming done? Is it through the Ford Performance Power module? Or some other means?
mpeugeot
74Weld likely has Ford Performance pre-program them or programs them on a bench. It is not terribly difficult, if you had a stand alone CAN bus module (like a Gateway Module), it would be simple enough to power up the rack and program it.
userdude
userdude
Denton, TX
2023 2dr Badsquatch
Y'know, that's interesting; Quinn's referred to having a guy on staff, however if you're buying 100 racks at a time, maybe you could get that thrown that in. Interesting. I'm also guessing he's returning the unused housing so doesn't pay core charge. I wonder how much he's paying... lol
