Bearcat1
Travis
2017 Expedition Limited, 2006 BMW 330xi
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Yes,
KICKER KEY 200.4 POWER ADAPTER $10
PNP has recently been including this with the PNP harnesses for free. Mine came with it, but I chose not to use it. You’re all convincing me I now need to use it, lol.
Lurker B6G
Murph
Cleveland, OH
Ford Explorer Timberline
Sent PnP an email. They want $7.50 to ship a $10 power adapter which should have been part of the initial buy. I have bought two harnesses from them in the last year, so will see if they can do any better...
GreyCactus
Southern California
What does this power adapter buy you? Just curious.
Couldn’t you just clip off the power wire to the amp and attach a long run to the battery?
dangerfoot
Justin
Austin TX
www.dangerfoot.com
White Wildtrak 4dr
Apparently the head unit connection wasn't providing enough power...this in theory should.
I'll install this weekend most likely and report back.
greatlakes
Grand Rapids
67 Buick Special
Yes. Make sure you install an in-line fuse.
P_Baff
Pierre
'12 VW GTI & '21 Ford Bronco
Hey all:
So I have my 200.4 setup without the power adapter and the gains are all the way down. Does anyone here have their gains up without the power adapter? After Vol. "17" mine clips pretty hard.
How far up can you go on the volume before it starts to clip with the power adapter?
This could be the game changer I've been looking for as initially I was disappointed I couldn't get the gain higher on the 200.4.
Thanks!
MannyG20
Ted
F-150
Hey all:
Thanks!
I have my gains set at about 40%. I never set the volume over 11 or 12. It never clips.
I don’t know how y’all are able to stand the volume at 15+. 😱
P_Baff
Pierre
Do you have the power adapter installed? After the pink noise DSP I couldn't adjust the gains on the amp without it cutting off. I don't have a power adapter...yet.
Bearcat1
Travis
Hey all:
Thanks!
My gains are at the minimum. Before adding power adapter direct to battery, clipped around 16-19 depending on the music, after power adapter clips around 20-23.
Bearcat1
Travis
Yes, but I would think you would also want to run a new ground as well. The cables on the adapter are doubled up wires for both power and ground. Bottom line, just like all harnesses, makes things a bit easier to connect.
GreyCactus
Southern California
Thanks for clarifying!
MannyG20
Ted
F-150
I do not have the power adapter. I set my volume at 17 when I did the DSP. Then I raised my gain until the speakers clipped. So I guess if I did turn the volume up to 17 they would clip.
