Synyster06Gates
Austin
Austin, TX
2022 Bronco Badlands Sasquatch
I just replaced all my speakers with kickers. I’m wondering if others have the same outcome. I get a lot more clarity and highs. The lower tones seem to have gone away. No real bass to speak of.
Do you have them amped? If not, you're not pushing them with enough power.
cmcbronco
Illinois
2012 f-150 FX4
If you replaced the kick panels with no amp you’re honestly going to kill your bass. The kick panels need power if you upgrade. If you don’t add an amp you should stick with the stock speakers there.
Djd7
Northeast
BD
Do you have an amp? The Kickers need more power than the factory head unit puts out.
ejaffe
New Jersey
Audi TT
Has anyone tried installing the Kicker amp without using the plug and play harness? it's a great product but $155 is pretty steep for what it is. Crutchfield will provide all of the directions and says there is no wire cutting so it can be returned to stock..
Bronc OH
Columbus, OH
1974 Bronco Explorer
Unless Crutchfield is making their own 'plug & play' harnesses that have the Ford adapters, you're going to have to cut into a number of areas unless you find the adapters to plug into the factory head unit and factory harness.
1.) how will you get power to the amp? on the PNP, this draws off of the factory harness
2.) how will you get powered sound to the factory speakers? You will need to cut into the factory speakers wires
3.) how will you sound inputs to the amp? you will have to cut into the factory wires
If you're good cutting/splicing into your factory wires to save $155, maybe listen to them. For me, the PNP harness was a no-brainer.
mikey_photo
Allentown, PA
2021 2dr Badlands
You will have to do some cutting/splicing and will also need to get an amp wiring kit. Once you include the price for the wiring kit, the PNP sort of becomes a no brainer.
KeithK
Keith
Ford Bronco
I can advocate for the PNPKits...truly simple process (after you take all the panels off/down) and get access to the audio plug. Couldn't be simpler...I got Kit 18 as I wanted a powered subwoofer in the back along with the Key 200.4 amp. With my updated speakers (and a lot of dynamat/polyfil) it sounds great. Highly recommend @plugnplaykits
plugnplaykits
Joe
Ct
THANK YOU
ldog77
Len
Maryland
2021 Ford Bronco OBX; 2018 Chrysler Pacifica
Do you have any pics of your install? I'm wondering where to place the 10" kicker hideaway amp. Seems there's not enough room under the front seats.
KeithK
Keith
Ford Bronco
I put the amp in the glovebox for easier access. There are other options noted in the forums. I'm debating on the subwoofer location. For ease of taking it out, I'm thinking of just velcroing it to my rubber mat for now to keep it from sliding around. I can quickly disconnect it from the harness if I want to remove it from the truck.
Ford Bronco Kicker Key Amp 200.4 Install DIY Video - Do this first! Kicker Amp in Glovebox
Puddle Jumper
James
Lewis Center, Ohio
2020 Ford Edge Titanium AWD
I just ripped the boom mat out of my kick panel speakers. Made it sound so muddy and hardly any mid-bass.
Did you cut a “port” in your boom mats too?
22BlackDiamondGreen
Shawn
Louisville, KY
2013 Ford 150 1955 Ford F100
Anyone who installed kicker hideaway in rear —— where did you ground it to
KeithK
Keith
Ford Bronco
I took the easy way out and grounded it under one of the screws that holds the anchor bolt down in the back. I have rubber mat covering it so was easier than one on the side panel...seems to work for my sub.
