P_Baff
Pierre
'12 VW GTI & '21 Ford Bronco
No popping issues with me. I would highly recommend bass blockers for your dash speakers though.
Are your gains set correctly? My gain is set MAYBE a 1/4 turn up. I opted out for the auto setup as I didnt want the sound to focus in solely on the driver seat.
Yes, I did in fact add the bass blockers. The initial setup sounded fantastic, but felt like I had to redo it with the new kick panel speakers in. The gains are still set at 0 and need to adjust after the AUTO setup is complete. Good to have an idea of where they should be around. Thank you.
Yea I had the same issue. You need to turn the radio detect button on on the kicker 200.4. Small button just press it in and it will stop.
I read that in here, but I wasn't sure if that was a button or LED. I'm going to try that. Thank you.
67BroncoG1
67BroncoG1
Ron
CA
'22 2D Squatch, '67 Bronco, '24 Grenadier -ordered
I'm fairly certain that you set the gains before running the auto DSP setup.
cmcbronco
Illinois
2012 f-150 FX4
The gains need to be at zero for the pink noise setup. Also if you have a subwoofer that needs to be disconnected or turned off as well. Head unit eq need to be flat.
67BroncoG1
67BroncoG1
Ron
CA
I just looked and you are correct. I'm going to install my component front speakers this week and I'll do the DSP setup correctly this time.
KICKER KEY200.4 4-Channel DSP Amplifier Owner's Manual - Manuals+
1. Set the KEY amplifier gains (AMP-1 and AMP2) to the minimum (fully counter-clockwise). Place all settings in the signal chain, such as the EQ on your head unit, to be disabled or flat. Disconnect any speakers or subwoofers not connected to the KEY amplifier, factory or aftermarket.
2. Close the car windows, turn off the engine, turn off the HVAC. Install the microphone to the top of the driver’s side headrest. Make sure the microphone faces up, pointing as straight as possible to the roof.
cmcbronco
Illinois
2012 f-150 FX4
Are you going to run the components in bi amp mode? I’m really likening the way mine is set up now but am curious as to how much better if at all the bi amp mode would be with components up front.
P_Baff
Pierre
Yup. The other thing that I hadn't done while initially running the AUTO setup at first was flattening the headunit EQ. I'm extremely curious how it will sound with adjustments to the gain and the headunit EQ after the pink noise setup. Should be night and day!
67BroncoG1
67BroncoG1
Ron
CA
Nope, I'm going to use the 3-way crossover that comes with the component speakers. The plan is to wire the kick panel speakers to the input on the crossover and then each component is fed from the crossover.
DonM
Don
Northern Cincinnati
2021 4DR Base Sasquatch 2.3 in VB
Just order Kit 11 from PlugandPlay. Got the Kicker Key 200.4 elsewhere. Hopefully have it in by the end of April!! If I need bass I'll try the 10" Hideaway first>
Puddle Jumper
James
Lewis Center, Ohio
2020 Ford Edge Titanium AWD
If I am using the additional wiring harness provided by @pluginplaykits for my Kicker Hideaway that connects into the Key 200.4 /headunit wiring, should I still disconnect the Hideaway Sub when running the DSP pink noise setup?
P_Baff
Pierre
Yes. Disconnect anything not powered or "amplified" by the 200.4 while running the pink noise setup.
Puddle Jumper
James
Lewis Center, Ohio
Thank you for clarifying. 👍🍻
22BlackDiamondGreen
Shawn
Louisville, KY
2013 Ford 150 1955 Ford F100
I watch a youtube video from Kicker that said do DSP first - that is my plan
BigBronco1
Mamaroneck, NY
2018 Silverado, 2021 XC90
So the one thing i couldn't figure out was how to keep pink noise playing through the head unit with the car off (because you're supposed to get out and opening the door cuts it off). I ended up just letting the engine idle while I did it. If someone has a reco I'm all ears.
cmcbronco
Illinois
2012 f-150 FX4
The engine noise will probably screw up the pink noise setup. Your bronco should stay on long enough to complete the setup just by pushing the start button without actually starting the vehicle.
BigBronco1
Mamaroneck, NY
Once I install the new Kicker speakers I just bought, will give it a try. Thanks.
