Kicker Key 200.4 Done Correctly
P_Baff
Pierre
'12 VW GTI & '21 Ford Bronco
AZCoyote
AZCoyote
Wiley
Phoenix
2024 Big Bend Sasquatch
Got it. A dedicated power cable to the battery. You definitely need that.
I was wondering how the wires on your white connector were so much larger. This seems obvious to ask, but you did run that straight to the battery and not a fuse tap correct?
So where the rest of us have a single harness that we’re plugging in, you have this additional harness piece that sits between your harness and the OEM wiring, right?
Ford Bronco Kicker Key 200.4 Done Correctly IMG_4642
AZCoyote
AZCoyote
Wiley
Phoenix
Ok. I think I have this figured out if my imagination matches what you see on the current wiring set up. You have both of these harnesses, correct?
Ford Bronco Kicker Key 200.4 Done Correctly IMG_4643
Ford Bronco Kicker Key 200.4 Done Correctly IMG_4644
