- First Name
- Rodney
- Joined
- Jul 14, 2020
- Threads
- 31
- Messages
- 2,858
- Reaction score
- 8,393
- Location
- SloKart, TX
- Vehicle(s)
- 21 Bronco 2dr, 26 Explorer ST
- Your Bronco Model
- Badlands
80...white with gold screaming chicken1980-1981 or 1982+ ?
Sweeeeeeeeet. A close family friend had the Bandit model with a 4 speed. He let me drive it as a 13 year old. It was a damn good cruise.80...white with gold screaming chicken
@RagnarKon did exactly that way. Changing from parallel to series will change the ohms from 2 to 8. That will be a lighter load on the amp. However, there are major costs to that approach.I apologize if someone asked this previously, and I know audio but not as much as others in this thread, but if the impedance is too low with the speakers wired parallel from the factory, couldn’t you cut off the adapter, and adjust the just wiring for the the kick and dash speakers to align series configuration? I know it will increase the impedance but the amp should be in range this way and you aren’t using extra channels for the front and taking away from the rear. Yes you would have to verify speaker wire colors in the dash, and make sure they are in the right configuration, but is there a downside to this line of thinking? Seems easier and allows you you still run power to the back pods with one amp.
Hey Wiley, I'm sure you said already, but what box is that?All told, the Key 500 install with Additve Audio 3d box and Kicker L7T 8” went pretty well. Taps off the factory sub harness gave good low level signals. Fitment is excellent. I put tons of deadener in the area with focus on any area the box might touch.
now, I almost came on here to complain about poor performance. Then I went for a drive to assess why I wasn’t getting as much bass as expected. I did the gain setup. Check. I did the DSP setup. Check. What could be the problem….
Alas, I committed one of the classic 3 blunders. The first two of which are….
1. Never get into a land war in Asia
2. Never go in against a Sicilian when death is on the line.
3. Make sure your fader is set to center before you do your gain and DSP settings on your sub amp. I had my fader to front checking out balance of the kick panel to the dash and forgot.
Realized this during my drive and fixed my fader. Blammo! It is fantastic. Tomorrow I have to pull the panel and reset my gains and DSP but at least I know that there’s plenty of output there now. It has more than enough bass keep up on all of my test tracks and my favorite music. Two thumbs up highly recommend.
Additive Car AudioHey Wiley, I'm sure you said already, but what box is that?
Assuming you mean you are now wired with amp 1 to dash and amp 2 to kicks. Did you set the dip switch for bi-amp mode? That enables crossovers.@AZCoyote I just got done and went to set my gains. Volume at 25 and limiters all the way down, counter clockwise, and the lights are already on. What's up with that? Do I need to use the pink noise or just my music on the gains?
Anyways, it does sound way better. I do need to get a sub though!
Yep, all was done the way you said except for doing gains with pink noise. Thanks for all your help and contribution to this forum!Assuming you mean you are now wired with amp 1 to dash and amp 2 to kicks. Did you set the dip switch for bi-amp mode? That enables crossovers.
I use volume at 24 since I think that is closer to when the HU starts to distort. With gains all the way down use the Lab Grade Pink noise WAV file from kicker.
https://www.kicker.com/key2004-testtones
Raise the gains until they clip. Then lower until the light is off. Then you can switch to music. Best method is NOT to raise gains after doing the pink noise step. Play some dynamic music (HU still at 24) and check for clipping. Lower the gain if there is clipping. Leave it alone if there is none.
This assumes you did the DSP first which is what you should do with the gains all the way down. Dip switch settings as mentioned on page 1. Btw I had another pass at the manual and EQ dip turns on a bump the Kicker people like so you may like it off. Delay is supposed to correct for HU doing time alignment. You may not need that. You can turn the HU setting to not favor any seat (all seat I think it says) or use Forscan as mentioned before. Just make sure DSP is done before setting gain.
I can wholeheartedly recommend the one I linked above. It’s is fantastic for a hidden solution. Just about $800 delivered for 500 watt amp, box, sub, and bass control knob. I am very content with it. I sent my 3 college age kids to the store today and they came back all smiles.
I have the same harness. If you haven't found your answer, purple is + right, black is - right and green is + left, brown is - left.I am working on the modification right now and my harness does not follows exactly the color diagram in the manual. See the purple of right rear is paired with black. That is fine. But then I have a question about which line is the positive output? Upper ones (black in this pair) or lower (purple)? My guess is purple, but. I want to confirm. Thanks.
