Kicker Key 200.4 amp Disappointing
Zzoop28
A
2023 bronco
I did the Kicker Amp 200.4 install with the plugNplay harness. Install was nice and easy with that harness. I have the 7 speaker non-B&O stock setup.
Maybe I'm too picky, but it did not do much for the stock speaker sound in my opinion. Basically I lost all low end range/bass and sound adjustment. The mid/highs do sound a little clearer, better than stock, but you lose so much all around sound that I do not think it was worth it. I will say after re-doing the kicker mic setup routine for the amp a couple times, it got a little better. just my experience, but i expected more from all the other post i read.
67BroncoG1
Ron
CA
'22 2D Squatch, '67 Bronco, '24 Grenadier -ordered
If you lost low end then you must have a setting wrong.
Zzoop28
A
2023 bronco
There are not really many settings to that amp. I went off the recommendations here for the dip switch settings. Anything specific you're thinking of?
-Thanks
67BroncoG1
Ron
CA
-Thanks
Did you go through the DSP setup? It isn't going to make it an audiophile system but it is a huge improvement for a relatively small spend.
83XLT
Carl
Cincinnati
22 EG Big Bend 2.7
I replaced the front speakers first and was disappointed. Then I added the 200.4 and was blown away by the dirrerence. Maybe its worh the $200 for new dash and kick panel speakers. maybe its your settings. Posting my settings for FYI
Ford Bronco Kicker Key 200.4 amp Disappointing PXL_20220907_183303238
Oh if you haven't done new speakers with the amp - that's part of the issue right there. I mean, it shouldn't sound worse, so there's something going on, but it won't sound nearly as good as it could for a relatively small investment in even modest aftermarket speakers - particularly the dash ones.
DefNotBuddyLee
Austin
Mustang / Jeep / F150
As others mentioned, if you only did the amp and have not replaced the stock speakers I don't think you are getting full advantage of the Kicker Key. Speaker brand/model will definitely play a part in the sound you get as well.
Dan-O
Dan
Fountain Hills, AZ
Dip switch pic settings is showing u have the 120 HZ filter set….somebody correct me if I’m wrong😑? That would explain why you don’t have any low end…..
Zzoop28
A
2023 bronco
Yes i did the DSP setup multiple times, it did get a little better on the 3rd try.
I was planning to start replacing speakers next as you all mentioned with JL.
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
Also make sure you have "speed volume" turned off in your audio settings when you do the DSP setup...I forgot this and it really does make a difference!
KillerPenz
North East
Also check the "gain", my speakers (rear) were quiet until I started messing with that. But don't turn it up too much that will cause a crackling sound. I didn't read this entire thread, did you do any of the Forscan changes?
I still say the speaker bar software update is the way to go. Brother in Law did that (as he had speaker bar) and it still sounded better than my set up with the kicker key. Only problem was, 2 years ago not many Ford dealers near me were doing that.
TahoeDog
CA
Bronco Wildtrak 2023 2 Door - Pepper Red
What is the speaker bar update?
swamp2
EQ on for me has abysmal sound, unlistenable (after successful auto EQ). However, with no EQ is completely transformed my stock system. I'd suggest to not just set no EQ (press mic button until 2 beeps) but rather clear the EQ (hold button for 10 sec until beep). Mine has unexpectedly auto reverted from no EQ to EQ.
FreddieLee
Freddie
Bronco & Tesla M3
A simple flip of the EQ dip switch is the correct way to disable the applied EQ settings following auto-tune. Using the mic to toggle reverts back to factory, reduces output, removes speaker time delay / alignment, etc.
IMO, bad suggestion. You're definitely in the minority on this one.
rainman23
Ray
Salem, OR
F-150
I have the amp installed with new speakers all around (including 6.5 rears). I also added a small hideaway sub. I have done the Forscan mods. Sound is better than stock, but not quite what I was expecting. I know the DSP has not been done and I want to do it. I’ve seen the directions and understand the basic process. This is a topic I really don’t understand well. Are there some tips and tricks that really help the DSP make a difference? What settings should I put into the factory EQ? Saw the suggestion to turn off speed sensitive volume. I am assuming that the installer picked the appropriate amp settings and I just need to put the right settings into the factory EQ and run the Kicker DSP program.
