Key Fob not detected.
UnderTheSea
Tara
BC, Canada 🇨🇦
2023 Ford Bronco Badlands Sasquatch
I've read a few older posts about this, but my experience is a little different.
I've had this happen multiple times where it'll start up and tell me the key fob isn't detected. I can still drive it.
I can also start the Bronco with my phone, so I thought maybe that was why I can still drive it? But I saw an older comment on a post that says it shouldn't be possible.
Has the issue for this been determined? I've had mine since August and have just passes 8,000 km.
JediMcMuffin
Tommy
2021 Bronco Badlands
Mind definitely started doing this after some updates, but I was thinking maybe it could simply be be the batteries in the remotes now being 2+ years old. I have not swapped them to test.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
da_jokker
Jeep Wrangler JKUR
I don't know if it's all or some, but I believe the remotes have a "sleep" mode that occurs when it hasn't seen motion for a bit (It is to prevent people from grabbing the signal when you put your keys down).
I mean the first step of course would be to try the second remote or replace the battery...however there have been some people that will like put their keys in the center console when they get in and the Bronco was complaining that it couldn't detect the key.
Typically if it is in your paints, you are moving you legs enough while you're driving that it keeps it happy.
Oh..almost forgot, there IS a TSB for this problem where Ford replaces the receiver I think.
meh
23 Eruption Green Wildtrak
This just happened to me. The car didn’t respond to any key clicks - I had to unlock it and then start it with my phone and then after getting in and out of the car several times it worked.
My car has 250 miles on it….
Jonboy199
Jon
Orlando
Buick
Hello, I have similar issue. For me we were driving on the trails and the no key detected would show up. Took to the dealership, Dealership replaced the battery in vehicle. The issue came back 2 days later. Bronco is back at dealership sitting now for 5 days no answers. At one point I was told they are waiting for a master mechanic to look at the issue.
SquatchBronco
Sara
Missouri
2022 F-350
I've had the no key detected a few times. When it's on my purse strap sitting on the passenger floorboard.
I also just had the key fob not work for the 2nd time last night. Wouldn't unlock, lock, remote start or set panic. I had to go into the ap both times and then the key fob worked. I've only had my Bronco since end of August with 3200 miles on it.
Beachbum
Lancaster, PA
2023 Bronco
This just happened to me for the first time. Drove the Bronco 10 mins ago. Walked away without locking it and came back now it won't detect the key. I can remote start and also remote lock and unlock but can't drive it since the key won't detect. 30 miles from home so can't try my spare atm.
Update: So I was able to use the Center console passive key start option and that was a blessing. Just need to figure out if it's a key FOB battery or something else. Got home and now the FOB works. Going to replace both batteries anyhow.
Zeekari
Billy
Having this issue bronco is 4 weeks old. Both key fobs when using them after work say no key detected.
HotLap
Bradley
CA Central Coast
2023 Bronco, 2024 HD Street Glide & 2019 Yamaha XSR900
Another possibility is your battery state of charge. I’ve had this warning on my 2018 Raptor and my 23 Bronco as a result of battery being low. Other warnings like ASS not working, accessories being disabled due to low battery, etc. Our Bronco’s do a lot of stuff when just sitting that will eventually deplete your battery charge if you’re not driving it regularly, and/or only driving short distances. If mine sits for a couple of days I start getting warnings from my Ford Pass ap that external options have been disabled due to low battery charge. Just installed a Noco Genius 5 maintainer, hoping that takes care of everything.
mjcutri
M
Lisbon, Portugal / Pittsburgh, PA
2023 Bronco HE
If you have pulled off eiither side panel in the rear, Check the connections to the antennas.
I was having this issue and found that I had forgotten to reconnect the driver side antenna. Plugged it back in and it works perfectly again.
Mscdman
P
Denver
OBX
Can anyone point me to a photo of this antenna wire? I’m gonna check mine…just got this message again after not having seen it for 2 months then after I saw it and used the center console passive start it works now with no message. 🤷🏻‍♂️
ThunderFlash
Doug
Washington
'24 4-dr WT, '22 2-dr WT, '15 Explorer Sport, '02 F250 SD V-10
Had this happen for the first time in a 2022 WT with Lux. Never had the rear panel s off myself, but I did have the rear sub rattle TSB work done at the dealer. Wife picked up pizzas and left the fob in the truck running along with my mother-in-law. The truck honked like the fob was removed when she got out. When she came back, truck is still running, but won't let her shift into reverse and is saying no fob is detected. So she shut it off and then it would not restart and had the NKD message. Figured fob battery was dead. I remote started it from the app so she had heat and drove up with the second fob. That fob did not work either. Hoped disconnecting the battery would reset the computer, but that didn't work. So I turned to the Internet! Found the info about the fob indentation in the bottom of the center console arm rest under the felt mat. Voila, fired right up. Drove home and tested it out and it seemed to be working normally again. Will replace the battery in both fobs, but that is stupid. 2015 Explorer has never done that. This must be technology advancements.
