KBD fender flares
IwannaGOfast
Jon
Brea, CA
2021 4 door Badlands, 1991 Ranger Long Travel, 2014 Cruze Commuter
Finished Installing mine on my Base Sasquatch. Love them so far.
Looks good. Did you paint these before or after install?
ThaSunn
Sean
Harlem, GA
06' Mustang GT, 22' Jeep Cherokee, 22' BD Bronco
This might be the best install of these flares that I've seen so far. Looks great!
Agreed, I'm thinking of doing these to match my white. A cheaper, more doable version of ADV fenders.
thrillswills
Mazda3
Got my KBD flares installed. I'm happy with the look. I had a bit of a problem installing the tape. Great support from KBD, and I understand they are going to start installing the tape before shipping the fenders so the customer won't have to. Now the important part.
These look awesome! How have your doors held up with rocks and stuff being thrown from the Sasquatch tires with less flare protection? That's my biggest concern at the moment.
JKommuter
F250, Escape
Well to be honest, only 6000 miles and only 1 real trail since installed. They don't offer much protection.
Diydner
Ryan
Winter Springs, FL
Ram 1500
Would someone with a 4 dr mind posting pics of the rear door install. Maybe with the door open?
Also, has anyone attempted to put the rear doors in the doormats with these installed? Do they still fit in the bags?
OddBall88
OddBall88
Joseph
Ford Bronco
Yeah they still fit
  • Like
Reactions: R11
AARDVARK122
john
utah
2007 volvo xc70
Ok so I have been working on a solution to fix the inner fender well on the rear of the bronco when installing the KBD fender flares. I think I have an inexpensive solution. I bought some trim lok molding and installed it first on body fender, before mounting the flare. This piece holds up the inner fender lining so it doesn’t look like it is falling off. (Ford did a lousy job with the inner liner. It was $20.00 for the trim lok off Amazon. 11feet was enough to do both rear fenders. If yours are already mounted. You may be able to loosen the screws and slide it on between the flares. But I have not tried it to know for sure. But if you are considering KBD flares, this made a huge difference for me in deciding to run these flares and not send them back to KBD. Hope this helps.
Ford Bronco KBD fender flares Subject
Ford Bronco KBD fender flares IMG_5234
Ford Bronco KBD fender flares IMG_5231
Ford Bronco KBD fender flares IMG_5229
Ford Bronco KBD fender flares IMG_5230
Ford Bronco KBD fender flares IMG_5232
Ford Bronco KBD fender flares 71875450964__287568E8-27E5-4FFF-AD5A-34EB9EF81ACE
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
The Stig lives! (or at least someone has found their camera)
Kidding aside, looks good. Thanks for the suggestion.
Blaylock1988
Colorado Springs
2021 Ford Bronco, 2004 Volkswagen R32
Looks good. I'm curious if it's something I could add after the fact.
AARDVARK122
john
utah
2007 volvo xc70
I think it might be possible. If you loosen the 4 bolts there might be enough room to squeeze the trim lok between the fender and the flare. Then tighten them back down.
Manx
Jon
Mach X
