KBD fender flares
mbuck45
New Hampshire
Ford Bronco
I’d love to see an install video. Just ordered mine, they look awesome!
LTKom82
Luke
Canada
I asked them on Instagram if they had any plans to make a wider set. They said it won’t work with the styling. Too bad, but they still look great!
Jazer
Jessica
2.7 OBX
Those of you that have installed, is there any areas where the flare can rub the body? (Since it goes up onto the normally exposed surface). In the event you wanted to go back to stock is it likely they would damage/rub anywhere? Or is their tape between them in all areas that touch?
OddBall88
OddBall88
Joseph
Ford Bronco
Yeah the tape is on it in all those locations.
nwGTS
Nate
Chicago, IL
Maybe this is the unpopular opinion but I think they'll only look good on the non-SAS offsets and pizza cutters.
And I do think they could get away with a slightly wider fender but I understand what they mean by going too wide ruining the look.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I agree. I’d get rid of my spacers on my steelies and rock these - only if they were not adhesive mounted.
fields_day
San Antonio
2022 4dr Badlands - 2023 2dr Black Diamond
Finally got my Eibach coilovers and these flares put on. The two sided tape was already installed on mine, a lot of them are already separating from the body after installation, so like a lot of people are saying here I'll probably have to pull off and redo with better tape.
A quick shot from the front. I'll get better pics soon. I'm on 37s with a -12 offset.
Ford Bronco KBD fender flares 20221125_162422
zeeps
Memphis
'22 Outer Banks
Mine are arriving today. Any tips for the install? Seems to be pretty straightforward from what i’ve seen, but i’m a little worried about the provided tape not being enough.
Trooper19
Maple Ridge
2022 Badlands Sasquatch 4dr
I would like to see a stock 4 door Badlands Sasquatch with the original 35" tires with a set of KBD fenders installed.
zeeps
Memphis
'22 Outer Banks
Installed mine today. First off, there were no screw holes punched through on one of the front flares. I just drilled them out. Easy fix, but slightly annoying. The most trouble I had was peeling off the back of the double sided tape without pulling at the corners that make contact with body. It’s slightly disconnected from the body on a few spots as a result. Also, making sure the door caps are lined up was not fun. I was over confident after getting the driver side right and the passenger side doesn’t look great.
I will likely take it somewhere to see if they can do a better job.
Ford Bronco KBD fender flares 53DBC4D4-9A99-4A27-8092-6C2DC81F189E
BaseBlackCoupe
Geoffrey
Nebraska
2022 Bronco Sport and 2022 Bronco
I saw these are listed at $350.. is that the standard price or is that marked down for black Friday cyber Monday? What did you guys pay? Thanks
Geoffrey
ThaSunn
Sean
Harlem, GA
06' Mustang GT, 22' Jeep Cherokee, 22' BD Bronco
Angle pics? Tire poke pics? thanks!
GPPBronco
Detroit
linktr.ee
‘23 Toyota 4Runner TRD Off Road
This thread cracks me up. We all want these flares to be The Answer. But, down to a person, they fail.
