Just put this shackle on
JonD
Jon
Maryland
Suburu Outback
Looks great installed. Installed lock for this and then about to install lock for Red shackle. Those seem to walk away allot.
Ford Bronco Just put this shackle on 20231005_100952
2023bronco
location
vehicles
I don't understand why people leave removable shackles on when not in use. If you stowe it, it won't "walk away."
BLTN
Colowado
'23 Badlands; '95 Jeep XJ; '07 Camry
Cool factor?...or, in my case - laziness.
Mine are beat-up bare steel and not that attractive anyway...
BigHoof
PA
Ram 2500
A couple years ago, someone at work left theirs in. When parking, he backed into a space and the ball went under a wire that went around the lot. He was one of those run to be first out of the lot guys so it wasn't pretty when he wrecked a bunch of cars at the end of the day, mine included.
Dubsesd
Andrew
CT
04 Ford F-150, 06 Roush Mustang
one less step to do when you need it? Also not that it takes up much space but if you leave it installed you don’t have to worry about storing it. To each their own.
BigHoof
PA
Ram 2500
Here they would turn to rust and be permanently welded into the hitch.
One thing though with the spare on the rear, you would not have to worry about smacking your shin on it unless the door was open. ;)
HotdogThud
mk6 gti, '21 MoarDoor
Every single time I tow my popup up to go camping, this is exactly my life.
Dead shins. Every. Time.
BigHoof
PA
Ram 2500
Even worse if you keep your ball greased. Been there, done that.
MNBigfoot
MN
My hitch with a 3 1/2" drop just clears, how is that 3 ball mount with zero drop usable?
PC Austin
paul
Plugerville, Texas
2023 Bronco Badlands
Just say no to hitch recovery points. They aren't safe and you can kill someone.
Are you referring to ball hitch recovery point or any hitch recovery point? Wouldn't these be safer with the proper care?
Ford Bronco Just put this shackle on 1696539068812
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
The tow hitch on any vehicle is designed for towing and attaches to a lateral frame member. The forces incurred in towing is different than that of a snatch to overcome a vehicle stuck (mud having the greatest suction force to overcome). You want the force used in such a recovery to be applied to a recovery point that is a part of the longitudinal frame member.
It was just a week ago that a recovery went wrong at the Ol' Florida offroad park. Landcruiser was stuck and recovery was attempted from the tow hitch. In a split second, the entire hitch carrier was torn off the LC and sling-shot into the rear gate of the recovery vehicle. People standing around in the kill zone unknowing the danger that they exposed themselves and their loved one too. In that split second, the carrier could have easily killed them.
Ford Bronco Just put this shackle on 1696540435901
mcinfantry
Lee
Louisiana
Badlands 2 door
As an auto adjuster i always recommend leaving the receiver IN. It’s keeps me busy and i enjoy totaling peoples vehicles for bent frames.
Beach_Bum
St. Augustine, FL
Makes sense. Terrifying. So many mistakes happened there. They are very lucky.
The video was quite dramatic. No way to post it here as it was posted in a private group. Not much to see other than hearing the rev of the recovery engine and the loud cavernous smash of the carrier hitting the gate. That carrier would have severed limbs of those standing around as quick as it happened.
People need to understand that the phrase "kill zone" is not being melodramatic. In this incident, it very well could have been deadly.
But to get back to the point of hitch recovery points, just use the intended recovery point a few inches to the left or right. If you don't have a hitch recovery point, you'll never be tempted to use it.
