Jump(push) starting 2.3l MT
kodiakisland
kodiakisland
Arkansas
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
Or even better a fully charged battery.
But, can it be done?
guess you need to do a test run to be safe. Mine is an automatic šŸ˜€ so I can’t Try
kodiakisland
kodiakisland
Arkansas
You're asking an awful lot to expect a modern car to run with no battery.
Yeah, I know, but one of the benefits of a manual has been able to start with a dead battery. Kinda nice in a vehicle off the beaten path.
Oldhippie
Barry
Santa Cruz, Calif.
BMW X1, ā€˜1928 model A, ā€œ23 Bronco
In my mustang ya got to have the clutch disengaged (not brake) to start...don’t know if the ignition stays on without engine tuning over? Sure can’t get the engine turning with the clutch in...
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Good question.
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
Bronco is the same. If you hit start button on 7MT without clutch pedal depressed, you get a message on the screen saying depress clutch to start.
I can't see how push starting a Bronco could work, but this is an interesting thread and the push start has saved me in the past! (probably 30 years ago last time I did it šŸ˜‚)
BL-CT
Danbury, CT
volvo
I tried roll starting my MT Badlands last fall and could not get it to work. It threw all sorts of errors (which reset once the ignition was off). What I tried was rolling down a hill with ignition ON then letting the clutch out once it was fast enough.
Parking brake was not an issue but engine didn’t start no matter what I tried. Battery was full. I was just testing to see what if (i.e bad starter motor).
This is the first modern MT car I own and I’m wondering if all modern MT cars are like this.
harpo
not as many as I thought
What? One of the main reasons to get a manual is the push start.
There has to be a way...
BL-CT
Danbury, CT
volvo
I agree. It would be nice. But it looks like it will require tempering of some sort.
harpo
It never occurred to me that you wouldn't be able to push start a manual.
I've push started cars hundreds of times ( yes I was poor and couldn't afford a new battery ).
Now I'm going to have to check if my current manual can be push started.
BL-CT
Danbury, CT
volvo
let me know.
harpo
let me know.
My 2016 manual will push start.
But there are 2 levels of ignition on, the first spot turns on lights radio etc, but it won't start. The second spot turns on all the engine controls. Ie all the engine lights light up.
Does the bronco have multiple ignition levels? It's easy with a key, 1/4 turn for radio, another 1/4 turn for motor control, another 1/4 turn to fire the starter.
Not sure how that translates to push button start systems.
mcinfantry
Lee
Louisiana
Badlands 2 door
You generally need enough voltage for the pcm and injectors
I don’t think it would work
BL-CT
Danbury, CT
volvo
The Bronco start button has two stages.
first push- dashboard comes to life
second push + clutch- engine starts.
The issue with the Bronco might be the ā€žclutch depressedā€œ requirement.
Once you are at speed and let go of the clutch the engine is mechanically engaged by the transmission, but it doesn’t start combustion because the ignition is not really on. The missing clutch signal and maybe other conditions we don’t know of are preventing it from coming on. I will try jumping out my ā€žclutch depressedā€œ switch and test it again. But it will be a couple of weeks until Iā€˜ll have time for it.
Iā€˜ll let you know.
Does your 2016 require that the clutch be depressed on a standstill start?
If so I wouldn’t expect it to roll start either. But it did.
