JCR Shock Skids
Status
Not open for further replies.
PCDan
Dan
Park City
1968 Ford Bronco
FYI - Due to the slight variations in the lower shock mount angles these JCR shock skids can be off from being lined up with the shock. After sending photos and emails of how crooked the passenger side skid is on my Bronco Mitchell at JCR said “ I don’t see an issue with that” . He doesn't see an issue with the skid mounting crooked, but some of us probably do. The angle also puts the skid closer to the trailing arm, whether it’s stock or aftermarket like mine.
https://www.jcroffroad.com/product/BR6SD-SH.html
Ford Bronco JCR Shock Skids 9801BF76-3401-4CAA-9543-5D39EDC67BF8
Ford Bronco JCR Shock Skids 2A125637-F8C9-4EED-AF7E-E65644DF0083
Jr87mustang
Josh
Northern Cali
Wow, thats quite a difference from side to side.
PCDan
PCDan
Dan
Park City
1968 Ford Bronco
Yes it is. And because of the height of the skid, just a slight difference at the mount makes a big difference at the angle of the skid …. But JCR/Mitchell doesn’t see any issue with it lol 🤪
The shorter skids made by other manufacturers won’t be nearly as effected by the mount angle variations, and wont interfere with the trailing arm.
mike8675309
Minnesota
What is the cause of that? Were the bolt holes placed improperly or is it just tweaked and if you hit it a few times with a dead blow hammer you can fix it?
chtucker
Kirkland, WA
FJ Cruiser
Pretty much the same response when I mentioned the camera relocate brackets weren't aligned and the camera cable being 20' was ridiculous. Yea there have commented about the winch plate not aligning as well.
It would be bette if the response wasn't a shrug their shoulders.
AZSky
Scottsdale, AZ
Heritage, Mach E, EV6
Does it affect function or is it esthetics only ?
IwannaGOfast
Jon
Brea, CA
2021 4 door Badlands, 1991 Ranger Long Travel, 2014 Cruze Commuter
I'm curious about your lift setup you have. The truck seems to be pretty high and at an interesting angle compared to the garage door.
kahunabob
Bob
Santa Clarita, CA
4runner
JCR has a bad reputation in the jeep world...seems like they are getting there for Broncos too. I would be careful of their products.
Keerplunk
Izzy
Burbank CA
2007 Jeep JKU, 2022 Cyber Orange 4Dr Bronco
Have you checked the angle at ride height? the Track bar tends to pull the axle to one side when lifted all the way up
PCDan
PCDan
Dan
Park City
1968 Ford Bronco
It will rub against the trailing arm at full droop. Not just esthetics.
PCDan
PCDan
Dan
Park City
1968 Ford Bronco
Its on a two post car lift 5’ off the ground
Destroyer
2002 Chevy SWB NBS, 2022 Bronco
Been in the Jeep world for years and have never heard of this "bad reputation". Would be interested to hear/see some examples of this. Disappointing to hear they don't think a very obvious manufacturing defect is worth replacing
BAUS67
redneck
Central PA
You must mean compression because it is a full droop now. On a lift with the wheels off the ground. Full droop.
kahunabob
Bob
Santa Clarita, CA
4runner
I was in the jeep world for a long time..not on the forums for a couple of years since I got rid of my LJ...but a quick Google search:
https://www.jlwranglerforums.com/forum/threads/jcr-not-standing-behind-their-part.38020/
https://www.wranglerforum.com/threa...nce-is-turning-out-to-be-frustrating.1224065/
https://www.jeepforum.com/threads/how-does-jcr-offroad-stay-in-business.1091425/
I remember many more from back in the day...but I am sure your own google browser works good enough for a quick search.
Status
