It might be time...
ABorges
Art
Fresno CA
1973 F100
I was going to buy new but prices are crazy, so I have found a couple used ones that I am interested in.
I am out of touch with specs and options by now so just looking for opinions, hopefully somebody has one.......:wink:
2022 Ford Bronco Badlands 2.3ltr - 93000 km - $45 000 CAD
VIN: 1FMEE5DH8NLB27410
or
2023 Ford Bronco Wildtrak 2.7ltr - 13000 km - $64 000 CAD
VIN: 1FMEE5DP1PLB12287
Sorry for the Canadian lingo
Just looking for the main differences, I have a RZR for fun so the Bronco will be a daily driver with probably no off-roading.......
For your use, either a Base model or a Big Bend will be all you need, saving you some money.
crzyhawk
Virgina
2024 Bronco, 2008 Mustang
I dunno. His location is Winnipeg, and I had a friend that lived there and complained about the bitter cold. I think she said there was a lot of snow and ice as well. Standard base or big bend risks not having 4A, and if I lived up there I think I might be willing to spend more for the peace of mind that 4A brings me in bad weather.
Between the two, I think I prefer the Wildtrak. My guess is that the HOSS 3.0 is going to feel better than the Badlands' suspension, it's got a bit more power, and it's not lugging around armor that isn't needed, though it (the armor) might be useful for blocking other things underneath from road salt.
If money's an issue though, the Badlands is significantly cheaper. Personally, I think I'd want the Wildtrak but be willing to pay for the Badlands.
Madcars
Winnipeg Manitoba 🇨🇦
Dodge Ram, Hyundai Tucson, Focus RS
Winnipeg yes, -45 celsius some days.
1 -2 feet of snow regularly.
40 minute commute 1 way from the country.
Money is always important but not too much.
Just found a 2024 2 Door, Badlands on a lot 2 hours away......going to look tomorrow.
mpeugeot
Buy once, cry once. The WildTrak is HOSS 3.0, heavy duty steering rack, V6, and a year newer model. If it is a lux or high package, that is the one I would get.
23OBX2.7
AB Canada
2023 Bronco
Both are horrible on freeways don't even think about an evasive or sudden directional change at speed.
Dealers are discounting '24 cad 15K and should be able to get 8-10k of '25.
Area51BS
Ron
Badlands non SAS 4dr 2.3
Badlands has the sta bar disconnect. Since it will primarily used on road, that feature will help running up on curbs.
Skeeterjack
RON
Goderich Ontario
2018MUSTANG GT
Don’t be thinking about good gas mileage,if it’s going to be a daily driver. SAS gives it the look that other models just don’t look as good. Unless you lift it. Outer banks would be your better bet if you can find one. With all recalls aside, its a fun vehicle to drive.
Truckin
Not far enough away from Chicago
Bronco (retired)
25 badlands sas here and have zero issues on the highway.
my only regret was should have went with Hoss 3 on WT. easy fix though as my Fox setup will be here soon
23OBX2.7
AB Canada
2023 Bronco
All I know when test driving the SAS and various lifted models on highway they felt like the would roll in a sudden evasive maneuver like avoiding animal, flying tire, stopped car, car crash etc or just an idiot on the phone going 40 in a 70 zone. Mind you that was coming from HPP Mustang that was on rails. I think it's the tires mostly plus high center of gravity and soft suspension with minimal anti sway bar.
For that reason alone I did not get and wasn't even going to get a Bronco till I changed on my brand new 2023 at heavy discount in a small town.
I would like however to upgrade my dampers with no lift.....is it possible? 98% street driven trashed roads rest is back roads....
Truckin
Bronco (retired)
Yes, there are coilovers with adjustable “no” lift.
Possibly shocks also but I always go up a bit and have not looked
23OBX2.7
AB Canada
2023 Bronco
I just have enough room with soft top folded back to clear some parkade mechanicals so can go up.
Any idea which dampers? They all seem to have some lift and I can maybe spare an inch at most.
mpeugeot
You could run the Bilsteins from the Badlands non-sasquatch (it's a 1/2" of lift, by but handling improved on-road over the factory Hitachi shocks). You will notice the better handling more than the 1/2" of lift could ever reduce it.
Oilbrnr
Scottsdale, AZ
'97 factory locked LX450, '16 Power Wagon w/FWC, '25 Bad/Sas/7MT
Comments like this always amaze me. You get a body on frame truck with 10+ inches of ground clearance on 35’s and you expect it to handle like a 3k lb. car. (and which you most likely never use off-road)
23OBX2.7
AB Canada
2023 Bronco
Top bad no active suspension.....no one is judging..... OP has questions I offered one perspective as a similar user...no expectations were expressed or implied I just conveyed experience of back to back highway drives of he different models.
As a frequent KTM mountain dirt biker I'm well atuned to weight and suspension calibration and had zero handling expectations of Bronco in general other that body lean and brake dive which makes it all that more fun!
23OBX2.7
AB Canada
2023 Bronco
Good tip it's viable for me ...anything aftermarket?
