Is it the glass... or the windshield angle?
JaredH790
Jared
Rosharon, Texas
2022 Bronco
IMO ... both
I've had probably 4 to 5 months of ownership (I bought new ... actually ordered it and took 20 months to get way back when) without jacked up front glass in some form or fashion. I refuse to replace it again until it becomes a safety issue for driving (currently only on passenger side).
Definitely going to get the protective film installed when I have to replace my current windshield.
Still love my Bronco though and still think it is awesome!
I’m Groot
25’ OBX SAS, 4dr, Hardtop, 2.7 /10. Lux, Desert Tan
Just lost our first windshield at 10k. Never even heard an impact, and we keep tons of distance on the highway. Ford glass contractor stated it wasn’t the heat cracking issue (it spontaneously cracked after sitting outside in high 90s temp with windows up). Waiting for the replacement to come in. We’ve got an appointment for PPF immediately following the new windshield install.
The Green Flash
Ken
The Sierra
2022 Outer Banks
I’m going to say this for the thousands of people who couldn’t tell you: Speed up or move to the right.
Go ahead and use that #2 lane to pass me, Ricky Bobby.
You do you, and don't expect me to get out of your way anymore than I'll expect you to slow it down and cool your jets.
Sherminiator
CNJ
2022 Ford Bronco Big Bend, 2024 Bronco Sport Big Bend
Stop driving so close to other cars.
Complete bullshit-my last windshield damage came from a rock from a car going in the opposite direction of me.
Surge
2025 2dr Bronco Badlands Marsh Gray
This doesn't stop crazy drivers from cutting so close in front of you. I don't tailgate and even I already had to get my windshield repaired. I didn't even notice it happening until I saw a crack starting to develop.
bargoffroad
Mitch
Idaho
2022 Ford Bronco
Dumbest and most ignorant take. 80k miles, original windshield, cracks running every which way. Just haven't bothered to replace. I know every single rock chip, and they're all from passing 18-wheelers on Idaho/Utah freeways going 85mph. Don't sit and act like you can't get cracked windshield unless you habitually tailgate.
T800
Rick
Riverside, CA
OBX SAS Avalanche Gray
Possibly somewhat valid if you're in a rural area and have the option to 'not follow closely'. I'm in CA and my commute always has traffic. So you can follow a little further back, but that will lead to being passed and cut off haha.
WalkerTR
Tony
Florence, Alabama
2018 F150, 1978 Bronco
According to the Auto Glass Safety Council (which also does repair work but are also involved in the politics), certainly a reason for the Broncos having so many broken windows is the angle. But there is a few things I didn't really think about. Here is some information from their website.
When your windshield is replaced, there are three categories of glass the shop might install:
OEM (Original Equipment Manufacturer) — Glass made by the same supplier that made the windshield in your car at the factory. Same specs, same thickness, same acoustic properties, same optical clarity.
OEE (Original Equipment Equivalent) — Glass made by a different manufacturer to OEM specs. Built to meet the same standards, often from the same raw materials. Functionally equivalent in most cases.
Aftermarket — Manufactured to lower price points. May meet minimum federal safety standards but not necessarily OEM specs for thickness, clarity, or acoustic properties.
Your windshield is a structural component. Federal Motor Vehicle Safety Standard 212 requires it to withstand up to 30% of roof crush load in a rollover. A windshield that''s slightly off-spec doesn''t hold the same way.
For vehicles with ADAS cameras, glass optical clarity matters even more. The camera reads through the glass. If the glass has slight distortions that lower-grade glass sometimes has, the camera can''t read the road cleanly. You can calibrate correctly and still have a system that under performs because the glass isn''t right.
Philvis77
Phil
2000 Jeep Cherokee
I had one crack in nearly 4.5 years. Got it replaced 2 months ago. Was changing my wiper blades Friday and somehow the wiper arm slipped from my hand without a blade in it. Needless to say, I now have 2 fresh cracks on my passenger side towards the bottom. They seem to be growing daily too. Ugh.
T800
Rick
Riverside, CA
Jeep has and option for Gorilla Glass. That would be a good option.
EasternSierra
Bill
Sacramento metro, California, U.S.A.
2025 Bronco Badlands 4-door 7MT, 2023 Ford Transit Connect van
Of course that's how it works. I let slide for a couple of years a windshield crack on a car I had. Finally replaced it, and the next month a new impact!
husker73
Wood River, NE
2022 Bronco
We've seen this debated quite a bit over the years.
Some people are convinced Bronco windshields use weaker glass.
Others think it's mostly the upright windshield angle taking rock impacts head-on.
After owning a Bronco, what's your take?
Have your experiences changed your opinion?
I believe it is the glass. 5 windshields so far. I also had a 2010 with 0 windshield replacement. Friends of mine have Jeeps and get chips which they can have filled. When my Bronco wind gets a chip it cracks within minutes. All from on coming traffic. i do not tailgate because I don't want a broken windshield but that does not help on coming traffic.
SHANUT
Craig
Hermann, MO
This is the right answer. Stop tailgating. It’s free and better for your paint too. 3,000,000 miles and counting and I’ve never had a windshield issue.
