Internal oil belt a future problem on a Bronco ?
Ducati1098
Completely different engine than the bronco has.
Considering the Bronco doesn't use a timing belt, I'd say it's pretty irrelevant.
Even for the oil pump belt issues on the 1.0 ecoboosts, the belt wasn't the cause of the failures, it was a faulty tensioner design.
We've seen one bronco oil pump belt failure, and it was on a 22MY after making it 250K miles.
raptorusmaximus
Horicon Wisconsin
2012 F-150 Raptor
How could it not? it's the same principal and the evidence seems to be clear. It especially bothers me that it could be dropping chunks into the oil beforehand.....
I've have several issues related to bad design already that were not part of any recall and should be, including rear engine seal (apparently common on ecoboost engines) and corroded coil packs to name a few.
A belt change was not designed into the engine to be easy maintenence, this procedure will be expensive. Changing the maintenance schedule just pushes the burden of fixing a bad idea that saved ford a buck back on us.....
Area51BS
Ron
Badlands non SAS 4dr 2.3
Today’s manufacturers engineer it to be most profitable and in Fords case, last somewhere between 3yr/36k most people’s typical average trade in date.
Sir915
Shawn
El paso
2023 Bronco
Not terribly worried I do feel someone will come up with a chain and sprocket replacement possibly? One can hope but if not I'm putting money aside for a v8 swap down the road
CalvinT
Calvin
Phoenix, AZ
Valhalla
Valhalla
Chattanooga Tn
THE SKY IS FALLING!!!!!!
