Interior question, What goes here? Ford part needed please.
navyaircrew
scott
michigan
2024 Ford Bronco Badlands non sas
So I tore apart my Badlands hardtop version installing sub replacement. Notice these corner spots. On softtop versions there a clip or tie down bolted in each corner. My hardtop version it looks like something is missing so I want to fill this corner with the ford piece. If someone could point me to a part number I’d be very grateful.
Ford Bronco Interior question, What goes here?  Ford part needed please. IMG_3859
Ford Bronco Interior question, What goes here?  Ford part needed please. IMG_3993
Ford Bronco Interior question, What goes here?  Ford part needed please. IMG_3950
RagnarKon
Ford Bronco, Escape, Focus
If you have the hard top, no part goes there. If you have the soft top... there is a latch.
Check the 6 minute, 48 second part of this video:
navyaircrew
navyaircrew
scott
michigan
Need the latch part number. It looks bare without it
Ford Bronco Interior question, What goes here?  Ford part needed please. IMG_3994
RagnarKon
OHHH.... so you want the latch even though you don't have the soft top?? Interesting, but here ya go:
M2DZ-78515A54-D
MSRP is around $650. Probably can find it for around ~$460 or so if you shop around I would imagine.
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
I would say get a piece of HDPE (high density polyethylene) plastic sheeting, cut a piece to fit, find the right bolt size, and plug the hole.
(I got a huge sheet off Amazon for $20. That’s a lot better than $460! 😳 )
Dipsy30
Robb
Oregon
23 Badlands Squatch
I do believe Stickerfab sells a blank that covers that spot
Johnkn
Maryland
'66 GT350, 68.5 CJ Mustang, B2, Viper, Pantera,TRX
Mountains 2 metal has a metal latch version for about $70 if you do think about the softtop sometime in the future
Y2KFirehawk
PA
2022 Bronco Wildtrak
The one I purchased prior on Etsy included bolts to fasten but it doesn't appear to be sold anymore. I found this which is similar.
Ggerobb
Gordon
Bennett, co
94 jeep grand cherokee laredo, 2022 bronco BD
Try a pull.shade. it's Mabett but looks really nice
Ford Bronco Interior question, What goes here?  Ford part needed please. Screenshot_20250316_072315_Amazon Shopping
navyaircrew
navyaircrew
scott
michigan
navyaircrew
navyaircrew
scott
michigan
M2DZ-78515A54-D
Goodness sake!!! That’s EACH. almost a grand for two plastic latches or whatever. I see how the are window catches for soft top versions. I about lost my mind looking for missing parts in the garage. The driveway. Like wth. Thank you for your help.
Bugkillah
Keith
North Augusta, SC
Base Sas, Badlands, Wrangler, Nissan Frontier
Yes. Exactly!! Man I looked for hours trying to find what I thought was missing parts when I took both my side panels off to install sound deadening. Goodness sake. It’s a perfect 10mm bolt I’m sure that fits there. And adding a tie down point makes perfect sense.
Great bracket, but 6mm bolt. I put the brackets and bolts on today, had to add 1/4ā€ flat washer.
