Installing a winch electrical considerations?
LanceIto
Lance
Boise, Idaho
2023 Bronco Raptor
Anyone using a quick disconnect? I was thinking about removing the winch completely to minimize wear due to UV and road salt. This would solve parasitic draw too.
GI_Jo_Nathan
Jonathan
I did the belt and suspenders method on mine, switch and disconnect. The bonus is my jumper cables hook into the quick disconnect. Flaming River makes good switches.
LanceIto
Lance
Boise, Idaho
2023 Bronco Raptor
Sorry I must have scrolled right by that. My bad. Question? Why both a disconnect and switch? Meaning to a dip sh!t like me is there benefits to having both. Also I am thinking disconnect in the winch side of the switch so I can easily remove the winch if necessary.
cynicalrider
First gen taco
How often are you removing the winch though? Not exactly an easy throw on/throw off setup unless you are doing a hitch mounted cradle.
I get annoyed just moving my morrflate kit between two trucks and got a second snatch strap to keep in this truck full time. There will be a time where you don't feel like putting the winch on, go out and then regret it. It's Murphy's law.
RollEmUp
Thousand Oaks, CA
21 Badlands Sasquatch
I used this tied in to an aux switch.
Ditto. Figured if I’m in a position where I need my winch, I may not be in the best position to pop the hood and make any connections. Aux to Warn 62132 Solenoid to winch. Use any aux switch you like 👍
LanceIto
Lance
Boise, Idaho
2023 Bronco Raptor
I have the RC high mount. I think the 4 winch mounting bolts are easily accessed. I live in region with bad winter and mag chloride. I was considering taking the winch off if I dont have a trip planned for a month or so. But I guess the reality is I would just leave it on.
nottinbe
St. Louis, MO
Bodge Garage
Kris
Millwood WA
1994 Land Rover Discovery, Jeep Gladiator
I did a switch and disconnect because my jumper cables are set up with the connector already so they just plug in. I leave the connector hooked up for daily driving but flip the switch off. Just a preference I guess.
Richterman
Badlands, Superduty
I don't know. i have a EVO 12 and the max current is 400amps, so i went 500 on the fuse
Bronco1010
New Jersey
2022 Bronco Badlands
Thanks for the info! I have a warn evo 10s. Warn's specs say it runs at 358 amps at 10,000lbs.
That being said, in you more experienced opinion, would a 400 amp mega be enough or will I need to trial by error?
cynicalrider
First gen taco
Yeah that should be fine just carry a spare just in case either way.
