Installed the OEM Slideout Tailgate
3wheelkhalil
3wheelkhalil
Khalil
Atlanta, GA
2023 Bronco
I was wondering if the Slideout tailgate works with the pull out cargo drawer also ?
Just watched an install video of the cargo drawer and I don't think it would work based on how they both mount.
Tye
Tye
San Francisco
Porsche GT3, Landrover Defender V8, BMW X3 Msport
is the top easily removable if you needed more height when hauling something and tbus u could just put it on the slide out portion
snowcatxx87
Canada
1290SDR EVO / 701SM / Tiger 900RP / Grom / Surron
Yup. It’s the best accessory ever. Got it from the factory and before it went up in price too. Way better than the fold down tray for the tailgate (and I believe they may not work together, it’s one or the other).
WIDirtFishing
WI
2018 F150 Lariat 2.7
Agreed. Installed mine this weekend. I love it.
its solid. It doesn’t rattle, and is gonna make loading the canoe 10x easier.
Johnny Mo
Westchester County, NY
teachu2shoot.com
Could you use it for laptop storage?
You could, but it's raw cargo floor under there, if you are planning to drive with the laptop stored there I'd likely get some sort of liner, rubber mat, carpet, towel etc to lay the laptop on.
Xrayphoton1
Houston
Camaro
Can you still use a rear cargo mat with it?
JawnyBronco
DelMarPa
2023 Bronco 4dr
Sure to contain dirt, liquid and such… you’ll lose access to the tie downs which I guess is always the case, but the deck has solid grip so nothing gained there…
JawnyBronco
DelMarPa
2023 Bronco 4dr
In case ur wondering, the Slideout Tailgate deck Can handle weight… 40 bags total in the rear…
Ford Bronco Installed the OEM Slideout Tailgate IMG_7705
jtrh0ne
James
Syracuse, NY
2023 Bronco Raptor
Though pricey, I have this and like it for the reasons stated above, particularly for the options it opens up for amp mounting like Johnny Mo shows in his pics and for fitting a compressor in a DV8 storage basket underneath. Also it does not interfere with swing gate mounted stinger sub/box - box just enough height to clear the raised floor when closed.
I'm curious if anyone has this slideout and a compatible security enclosure? From my minimal google kung fu, it appears most (all?) security enclosures assume factory floor mounts and therefore factory enclosure heights. Maybe I'm missing something.
