Boxer4
TRUCK
Well, this is strange. I should have dipped under the vehicle immediately before leaving the service center. But, this does NOT look like a new unit. Perhaps I’m missing something here…
Is that the front drive shaft ? Looks like it’s the rear.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Oh shit! Good call. I guess I didn’t realize it was the front in the first place - dunno why I assumed it was the rear. I’ll check that in the morning.
mpeugeot
I guess I lucked out. Scheduled service for my bunk washer fluid pump and they had a driveshaft in stock and replaced it this morning without question. I’m pleased.
Are you sure about that? ;)
That's why I used a paint marker and wrote "Failed" on my driveshaft. They better replace it, as the boot is failed.
I will know if it was replaced.
redone17
Cold Spring, NY
I’m a dumbass and jumped to conclusions. I forgot it was the front driveshaft. It’s still dark out - gonna get under and check the front this morning. I have a pretty stand-up dealer all things considered.
Boxer4
TRUCK
In one of these threads someone stated the failure is possibly caused by the front boot’s proximity to the exhaust.
There is a marked difference in the condition of the original front boot compared to the rear.
Once installed the placement will look fresh and new compared to the rear.
But paint works too.
Bdisco
Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
‘88 911,‘15 Chevy 2500, ‘24 Acura Integra Type S
I called my dealer to schedule an oil change and fix any recalls before we head down to Fla. next month. I mentioned the ‘drive shaft recall’ and she said that it was a ‘customer satisfaction item’ and they would only replace if I was experiencing an issue. She stated they would need to charge me a diagnostic fee to inspect the boot.
Shouldn’t the drive shaft boot and axle boots be part of the complementary inspection done during an oil change service?
I would not be a satisfied customer if my drive shaft boot fails and causes long term damage. Like wise I don’t think I would be happy having a valve give up and destroy my engine.
Ford Bronco INCOMING: Driveshaft Recall (Customer Satisfaction Program 22B27) - replacement needed to avoid cracked boot 1671455890797
‘21OBX
90Bronco19
2022 bronco outer banks
That’s the rear recall was for the front driveshaft.
They replaced mine with no issues. I had to wait for it to be ordered and arrive.
Boxer4
TRUCK
She correct. It’s not a recall. It’s a Customer Satisfaction Program. Maybe @flip can comment on how to convince dealers that it’s a non- conditional repair.
redone17
Cold Spring, NY
That’s the rear decal was for the front driveshaft.
they replaced mine with no issues. I had to wait for it to be ordered and arrive.
Yeah. I brain farted and updated with a pic of the replaced part a few posts after.
No questions asked. Mine wasn’t damaged or leaking.
Coldsmoke
Knuckles
Northern Illinois
Ford F150 Lariat
I'd get a different Dealer for service. After receiving the letter from Ford about the drive shaft recall, I called my dealer, they immediately got the part on order and scheduled a time for me to bring it in for the replacement. No "if's", no "buts", no "diagnostic fee".... done and done. (They also checked for the child lock issue at the same time, which was another Ford recall notification).
flip
Phil
IN
www.ruxerparts.com
Fords
Customer Satisfaction Program is the new PC term for recall. This is not a do it only if it has the problem, it’s a mandatory do it now. No idea why they wouldn’t want to do it, labor time, even for a recall is about spot on and the dealer gets a good markup on parts. All they need to do is order the parts so they’re there and schedule the appt. Takes right at an hour.
BlueOvalBandit
Kenneth
Anaheim, CA
Tacoma
Reading some of the service horror stories I was readying myself for a potential fight when I went in for routine maintenance this morning and was going to bring this up. I didn't even get a chance to mention it. Service manager brought it up as soon as they pulled my vehicle info up and said we're ordering the parts and they'll call me when they're in for scheduling.
Big shout out to Fullerton Ford Service Department for those in the Orange County area.
Boxer4
TRUCK
Thanks Phil
Cbiggs
Cory
West Chester PA, OCNJ
85 CJ, 94 YJ, 04 JK, 17 Taco
Uhg 🙁 just had the driveshaft replaced under recall on 12/27 after never noticing any issue, now there’s most definitely something wrong. Hope it makes it back to the dealer 🤬.
