Rear driveshaft bushing damaged - service recommend replacement
@BadBlueBronco
@BadBlueBronco
Kc
Los angeles
2021 Bronco Badlands
Ducati1098
Arokcrwlr
Kraig
US - Alabama
2014 F150, 2014 Focus, 1973 Bronco
The recall was for the front driveshaft. I’ve never had this happen on my rear shaft, but I know many have. @Bmadda recently made a thread where he upgraded to an Adam’s rear shaft, you may want to look into that instead of another OEM shaft.
https://www.bronco6g.com/forum/thre...tyle-driveshaft-installed.92481/#post-2214306
Mine is just like that. So far, there are no symptoms. What happens if it's run this way - what is the eventual failure? When I need to replace, I will give Adam's a call - definitely not going back to OEM.
Ducati1098
I’m guessing you’ll just get a bunch of debris/water in the joint over time and it could eventually just start to seize up and not move correctly
Felix808
SRV CA
I agree, it will just wear out the joint eventually. Personally, I would just leave it and replace the shaft with an upgraded more serviceable unit when the need arises.
I've been eyeing this one when ever the stocker is done 🤠
https://reeldriveline.com/product/2...4-door-automatic-transmission-reel-driveline/
