redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Thanks @flip - seems like they will convert to official recalls at the end of the month? I’ll keep posted here to find out others experience.
Shawntrex
Shawn
Kempton, PA
2021 f150
My build date is sept 29th and I DEFINITELY have the issue.
- Rumbling / noise at just over 50
- Crawled under confirmed boot is cracked, wet and the shaft moves up and down
- video attached (maybe)?
Called dealer to schedule. Was hoping they could pre order the shaft but was told they have to inspect it first and the soonest appointment is Oct 31st. I said it is part of a service bulletin. They said they never heard of the issue so I gave them the bulletin number. He said, oh yeah there it is, but it does not apply to my VIN.
Bottom line, this is affecting build dayes PAST Sept 17th. Maybe not far past but mine is affected and probably used a shaft sitting on a shelf during the build.
Brichan
Ram 1500
UPDATE: This affects all Broncos with build dates from 9/23/2020 through 9/17/2021.
Driveshaft Recall announced yesterday, 10/12/2022. Replacement needed to avoid a potentially cracked driveshaft boot. (Customer Satisfaction Program 22B27)
Don’t shoot the messenger 🤗
Dealer said it isn’t a recall, just an inspection. If it’s torn, they’ll replace, otherwise send you on your way. Mine was not eligible for replacement because it wasn’t torn. 🤷‍♂️
SuperFord
2013 Ford Fusion
as flip said, the person you talked to at your local dealer was mistaken. If you want it performed just call them back and speak to another advisor or ask them to read the dealer letter for 22B27.
John94
Detroit
4dr Black Diamond Sas
I was admiring the undercarriage a few weeks after I got it and had taken it to an OHV park and noticed the defective boot. Dealer checked with ford and replaced the drive shaft under warranty.
Built in November 2020. I thought I damaged it on trail, guess not.
how long did it take to get the replacement part in?
I am still waiting and mine is shit to drive at 70+ mph right now because of it
TinStar
Hellinois
F250SD, 67Gal
took a week for the dealer to get the new drive shaft.
1 hour tops to replace.
Brichan
Ram 1500
When I pressed them they told me I could get it done but if it happened again they wouldn’t fix it again. I’ll probably wait until next summer and make them do it regardless, since it expires next October.
John94
Detroit
Damn - my dealer Gorno Ford was annoying to make order the part. They order approx 1 week ago and are unable to give me an ETA on the arrival of the part.
I REALLY hope this doesn’t mean many more weeks prior to the part coming in. My vibrations are getting worse by the day..
RickDeckard
Kentucky
My dealer said the parts are back ordered until at least mid November.
John94
Detroit
Sigh. I was in my dealer the day this post was created - yet somehow I’m stuck in a back order log.
Lucky guy in this thread got his in a week. Must be nice
flip
Phil
IN
www.ruxerparts.com
Fords
The window must be a little wider than that. My build date is July 19, 2020 and I got the letter today.
Your sig shows built email of 7/20/21. It's possible they include more than what's in the original release but usually not that far out of the window.
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
MY BAD! I was totally misreading the year...I am in fact July 2021...I am going to delete that post thanks
flip
Phil
IN
www.ruxerparts.com
Fords
NP. Was going to ask for your VIN to make sure it wasn't sent in error and the recall did show up in OASIS.
Blaven
Pennsylvania
Just got my letter for this today. No issues with mine that I noticed so far. I will have to get under and check it myself to see if the boot is good. I'm still taking it in for this though. I'll be calling on Monday in hopes I don't get any issues from my nearest dealer about getting it fixed.
kodiakisland
Arkansas
Got my letter today too. Probably won't get into a big hurry to have it done.
