- Chris
- Mar 6, 2021
- 75
- 4,774
- 5,211
- Cold Spring, NY
- 2021 Bronco, 2020 Ranger
- Black Diamond
Dealer said it isn’t a recall, just an inspection. If it’s torn, they’ll replace, otherwise send you on your way. Mine was not eligible for replacement because it wasn’t torn.UPDATE: This affects all Broncos with build dates from 9/23/2020 through 9/17/2021.
Driveshaft Recall announced yesterday, 10/12/2022. Replacement needed to avoid a potentially cracked driveshaft boot. (Customer Satisfaction Program 22B27)
Don’t shoot the messenger
as flip said, the person you talked to at your local dealer was mistaken. If you want it performed just call them back and speak to another advisor or ask them to read the dealer letter for 22B27.Dealer said it isn’t a recall, just an inspection. If it’s torn, they’ll replace, otherwise send you on your way. Mine was not eligible for replacement because it wasn’t torn.![]()
how long did it take to get the replacement part in?I was admiring the undercarriage a few weeks after I got it and had taken it to an OHV park and noticed the defective boot. Dealer checked with ford and replaced the drive shaft under warranty.
Built in November 2020. I thought I damaged it on trail, guess not.
When I pressed them they told me I could get it done but if it happened again they wouldn’t fix it again. I’ll probably wait until next summer and make them do it regardless, since it expires next October.as flip said, the person you talked to at your local dealer was mistaken. If you want it performed just call them back and speak to another advisor or ask them to read the dealer letter for 22B27.
took a week for the dealer to get the new drive shaft.
1 hour tops to replace.
My dealer said the parts are back ordered until at least mid November.Damn - my dealer Gorno Ford was annoying to make order the part. They order approx 1 week ago and are unable to give me an ETA on the arrival of the part.
I REALLY hope this doesn’t mean many more weeks prior to the part coming in. My vibrations are getting worse by the day..
Your sig shows built email of 7/20/21. It's possible they include more than what's in the original release but usually not that far out of the window.The window must be a little wider than that. My build date is July 19, 2020 and I got the letter today.
MY BAD! I was totally misreading the year...I am in fact July 2021...I am going to delete that post thanksYour sig shows built email of 7/20/21. It's possible they include more than what's in the original release but usually not that far out of the window.
NP. Was going to ask for your VIN to make sure it wasn't sent in error and the recall did show up in OASIS.MY BAD! I was totally misreading the year...I am in fact July 2021...I am going to delete that post thanks
