iDash Pro software update, oil pressure added
ssls6
Richard
FairPlay CO
FJ Cruiser, Bronco, F-250
I saw there was a software update on Jan 15ish and installed it today on my 2025 BD 2.7L. They added a PID for oil pressure. Before asked, mine is showing 28-30 PSIG at hot idle (coolant 185F or so).
Ducati1098
Thanks for posting this. I wonder if they fixed the boost issue. I haven’t contacted them yet about it, but my iDash only reads a maximum of 23 psi for some reason.
I’ll have to update it and see if that was a potentially fix also.
PowerBronco
Steven
23 Bronco Badlands, 07 FJ Cruiser, 04 WRX STI
I'm going to have to revisit the idash. I've been wanting to get something to monitor oil pressure. Where are you all mounting the idash?
Ducati1098
ssls6
ssls6
Richard
FairPlay CO
That is the one I bought
Lenato
GCC
2door bronco, 981 cayman gts
That's great 👍🏻
Wonder why still can't read IAT2 (post intercooler), I've substituted with manifold air temps
Gluestick
Josh
Nashville
instagram.com
Explorer ST, Bronco Badsquatch
I still don’t know how to convert the values for temp and boost into something I understand but placement and vent function on this has still been very good:
Ford Bronco iDash Pro software update, oil pressure added IMG_8691
Ducati1098
That's great 👍🏻
They’re pretty much the same. One is right before the throttle body, one is in the intake manifold right after the throttle body.
Lenato
GCC
Yeah I figured and I'm just assuming IAT2 is average 5C lower than manifold reading based on comparing IAT2 readings using hp tuners vcm scanner
MachingBird
Christopher
Western, NY
2015 F-150 Lariat
Do you have a manufacturer or link to this one?
Bronco Toad
Todd
Central Ohio
2022 Bronco Badlands 4dr Cyber Orange
@Ducati1098 @Gluestick
What parameters can be monitored? What do you typically monitor? Assume a 2.3 or 2.7 does not matter.
Ducati1098
