How to Connect Compressor to Manifold
razehound
SoCal
2025 Bronco
Just got in my air compressor and 4 tire inflation/deflation system, but theres an issue: they both have male ends
Ford Bronco How to Connect Compressor to Manifold 1783724698829-9d
How do I hook it up? What do I need?
Any help is appreciated.
Thatguylegit69
Zachary
2023 Bronco & 2012 Ford Raptor
If wanting to keep the shut off, remove male plug, install threaded female plug from harbor freight.
If you don't care about the shut off, remove male plug to it, insert other male plug into female coupler.
Deadpool392
New Bern, NC
2025 Marsh Gray Bronco Raptor, 2020 Gator JTR (retired)
I bought this and installed female ends on both sides.
Minimprover 3/8" x 12 Inch Heavy Duty Short Air Compressor EPDM Rubber Hose 300 PSI: 1/4" Male NPT to 1/4" Male NPT Connections With Quick Coupler Brass Fitting https://a.co/d/01Cg0ACH
razehound
razehound
SoCal
2025 Bronco
That would be this one yes?
Ford Bronco How to Connect Compressor to Manifold 1783725404036-i7
And what exactly is the shut off for? Its my understanding that to stop to check the pressure, you just use the collar on the manifold (above the shut-off switch section) after stopping the compressor. Is that right? Or is that open/close slider only for deflating?
Thatguylegit69
Zachary
Yes, that would be it. Maybe look at the purple colored ones, as those are 'high flow'. Would be better use for deflating.
As for your other question, ive got no clue. I don't have one, just offering a solution to the issue.
Tricky Mike
21 Bronco
Looks like you have one of the 300 LPM jobbies? Easiest method is to clip off the Asian coupler and use a barbed automotive style coupler. If you choose to use a threaded coupler be ready for the compressor to have M10 threads that will have to be tapped to 1/4 NPT or adapted to it.
razehound
razehound
SoCal
2025 Bronco
uhh what?
Harbor freight worked just fine, literally screw out and screw in (with PTFE ofc)
