fallguy
Tennessee
2020 Defender, 2022 Outerbanks SAS, 1968 Mustang
After 3 years of using 4 hooks in the roof at the corners, and 4 ratchet straps, decided to get an actual hoist. Should have taken some pics of building it, but it is pretty straight forward. Watched the video from them on it, with a 4 door model. Looks like they have updated a few things, instead of a wire to lift it, now its a nylon strap which is much easier to setup. It can now be lifted up high enough to pull all the way under and make more room in the garage, and no more hitting my head on it when walking in the garage.
Ford Bronco Hoist a Top for 2 Door Installed Lift 2
Ford Bronco Hoist a Top for 2 Door Installed Lift 1
Ford Bronco Hoist a Top for 2 Door Installed Lift 3
Ford Bronco Hoist a Top for 2 Door Installed Lift 4
Overall pretty happy with it, paid $550 on Amazon for it. Should have done it earlier. Only bad thing about the roof being off me parking in the garage, is all my toys are taking up the room, and my wife has to park hers outside which I never hear the end of :eek:
Badlands Traveler
Mojave Desert
Ford F150 XTL 4x4 2019. Bronco Badlands Sasquatch
That Hoist system looks great! Who is the Manufacture? Thanks
helifino16
Ron
Mount Sinai, NY (Long Island)
Now THAT'S a garage full of toys.
Ford Bronco Hoist a Top for 2 Door Installed 1750863129738-38
fallguy
fallguy
Tennessee
fallguy
fallguy
Tennessee
I like them, puts the wife's outside though... and being 100+ right now in the south, not super happy about it haha. Sprinkler system gets it wet and then dries with hard spots... never hear the end of it 🤷
Ford Bronco Hoist a Top for 2 Door Installed Lift 5
totaljustice
Kevin
Middle Sackvegas, NS
Looks clean. I was trying to figure out what to do since I don't have a garage. This is what I came up with. It's a work in progress, the first time I used it I scratched the pillars pretty good, but I since added pool noodles to protect them.
I had the exact same issue because I don't have the height in my garage to clear the truck. I gouge the paint a bit driving out from underneath it. I ended up using some edge molding that I had bought to stop the infernal paint rub issue on the tailgate which did that job nicely. I ran this stuff along the interior edge of the roof, which was too sharp anyway. But it was an easy install and there is no more roll bar damage. Picture below of the stuff I used. It's an American company so you guys south of the 49th parallel should he able to find it easily. [Edit] And for you Canadian guys, you can find it at our GOD BLESS CANADA!!!! Canadian Tire.
Ford Bronco Hoist a Top for 2 Door Installed 20250623_105330
Ford Bronco Hoist a Top for 2 Door Installed 20250617_112121
Ford Bronco Hoist a Top for 2 Door Installed 20250625_175005
feeble
Shawn
Yankton, SD
2022 Badlands, 1977 Cobra II Monroe Handler
I already have a hoist. Anyone know if you can just buy the bracket (or maybe someone else sells just a bracket?)
Iceman62
Tim
Omaha, NE
2024 Bronco / Sasquatch
Very nice set-up - great job & thanks for the details! :D
MayhemMike
Mercury
Relying on those clips that fit in the roof rack slots to maintain the top bothers me. These tops cost to much to have them hanging that way. But hey, that’s me.
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
MFP2241
WV
2 Door Antimatter Blue BaseSquatch
Nice Guzzi. I've been on the hunt for a Sport 1100 for several years.
BigFootie
Wisconsin
The straps instead of the wires looks like a good improvement.
I like the idea that @totaljustice came up with as far as using the edging. I use 1/2 pipe insulation and remove it when almost installed. It also protects your head when walking under if you are taller.
Ford Bronco Hoist a Top for 2 Door Installed IMG_4282
BigFootie
Wisconsin
Can you post a picture of the motor and drum? I’m curious how different it is from the steel cable version.
fallguy
fallguy
Tennessee
Here you go, if you need anything different let me know. I never had the cable, but the strap seems to be better for usage and setting up.
Ford Bronco Hoist a Top for 2 Door Installed 20250629_091141
Ford Bronco Hoist a Top for 2 Door Installed 20250629_091148
Ford Bronco Hoist a Top for 2 Door Installed 20250629_091134
BigFootie
Wisconsin
Bummer, completely different motor. Now I also see they have a different version for the painted top. I’m reaching out to see what the differences are.
