- First Name
- John
- Joined
- Jan 24, 2023
- Threads
- 3
- Messages
- 147
- Reaction score
- 129
- Location
- Lafayette LA
- Vehicle(s)
- 2023 Bronco, 2012 Shelby GT500, 2021 Shelby GT500
- Your Bronco Model
- Wildtrak
You can get actual ECT readings by datalogging. I'm sure some tuning devices or phone apps can display actual coolant temps through the OBD port as well.Not saying OP is wrong or anything - he's clearing distinguishing between coolant and oil temps - but for some here there may be some confusion
I don't have a monitor hooked up so I can't see what Coolant temp is precisely, but I've never seen the coolant temp indicator budget from 4 bars (just short of middle of the gauge). I don't know of any built-in display on the IPC that shows what actual coolant temp is.
You can see oil temp in the Off Road section. That isn't the same thing as coolant temp though. My "normal" oil temp is anywhere from 195-225F, depending on how hard I'm pushing, what the HVAC system is doing, etc.
I could very well believe that a long haul at a steady 20psi boost could overwhelm the cooling system. May be time to consider manually downshifting or re-gearing lower to get to a lower boost value, holding at very near max boost for a sustained time is just gonna be hard on a lot of things there.
With that said, yeah, I could see a cooler T-stat holding the oil cooler down a bit longer, but I think if you are maxing out that 20psi boost thing indefinitely, you are gonna overwhelm that too - you need a bigger/more 3efficient oil cooler to go with it. All the T-stat is going to buy you is a bit more time before you get back up to just about the same temps you've been hitting - just a function of that oil cooler.
You say engine temps have nothing to do with oil temps, but there is a correlation between the two. You see the oil cooler on the Bronco uses engine coolant to cool the oil. If OP had a lower coolant temp for low load situations, he might not get as hot when he is in high load. My oil temps run pretty close to ECTs and declined with the lower thermostat. I don't haul a lot of weight.
You're running three times the maximum payload capacity of my 2023 WT. Cooling issues are the least of your concerns if that scale is accurate. 7,800# is a ton and a half over my 2023 WT's shipping weight. You might want to find out the weight ratings for both axles.And as for the problem Iām trying to beat, it looks like weight - and the end of this camping trip I hit a CAT Scale on the way home - 7360 lbs. Grossed up for the extra food, water, gas cans, ice and and extra passenger who wasnāt on the scale, I was at 7745 lbs fully loaded. Iāll weigh it empty this week after unloading.
