High Temps Warning, Boosted
B22-2023
Houston
After a warning or two on the cluster while on a long highway haul with full load and headwinds, I decided to look into a cooler thermostat.
https://www.lethalperformance.com/reische-performance-ford-50-170-performance-thermostat-gen-2.html
While the CS Fab radiator has reduced high running temps, I’m still seeing peaks unnecessarily at 20 lbs boost and tuned at 91-93 octane; I didn’t have my HUD up to see the coolant temp at that time. . But generally seeing up to 221 ECT and 243 oil temp at the high end during serious trail grinds.
After I install I’ll share results.
projectbadlands
Robert
Los Angeles
2018 Colorado ZR2
You are seeing high coolant temps when spooling? Or high oil temp?
GreyZ
Gulf South Louisiana
A lower temp thermostat will not help. It is 100% open at 200F anyway. So moving to a low temp tstat will not decrease the max running temp at all.
GreyZ
Did you block off the huge holes in the rad shroud after you removed the oem intercooler? If you did not that will drastically affect cooling.
Incinr8
1973 Dodge Power Wagon
Any ideas on the best way to do this?
CatMonkey
Lafayette LA
2023 Bronco, 2012 Shelby GT500, 2021 Shelby GT500
I disagree it won't help. I've been running a 170° thermostat for almost a year and my typical coolant temps stay in the 185° range. It might get up to 195° on a high speed run, but cools back down after a minute or so. I have no idea if fan temps are altered in the ProCal tune, but the short while I ran it without a tune didn't seem to change anything. Even on the coolest of days, it'll hover around 180°. In summer I always have the a/c on and the coolant fan runs when the compressor is cycling. As long as the truck is moving, the fans don't offer much additional airflow, where fan cycles don't much matter.
That big air dam in front of your intercooler in your avatar can't be helping your intake air temps which will promote heat as well. You might want to look into a high mount heat exchanger.
I'd recommend a coolant refill tool to refill your system after changing the thermostat. There's an EGR cooler that adds a bit of time to what should have been a simple thermostat replacement on my 2023.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Show us a pic of the front of your Bronco...I've been packed to the gills with a RTT on top, driving uphill in Death Valley in 120deg temps with AC with no issues!
BlueWaffle
Maine, USA
2023 bronco, and a trio of 80s GM's.
Man, when is the cooler thermostat BS gonna give up? Lol. Shits a bandaid at best, and a good way to lose both power & efficiency at worst..
CatMonkey
Lafayette LA
Ford sets their coolant parameters for these engines to run well north of 200° coolant temps. Cylinder head temps usually climb from there. Running hot Is all about gas mileage on a conservative tune. When is that a good idea for a tuned, boosted application to prevent detonation? Sorry, I don't see a downside in the hot, humid south. I'll take a 185° operating temperature over 210° any day.
B22-2023
B22-2023
Houston
I can’t think of a high output Ford motor I’ve had where it wasnā€˜t at least part of a solution worth investigating. Eco boost may be a different animal for sure, but easy enough to test, and cheap.
Not great flow to the upgraded IC maybe, but plenty to the radiator.
Ford Bronco High Temps Warning, Boosted IMG_0513
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
There’s your problem right there, your bumper is blocking your airway to the intercooler and rad!
Ford Bronco High Temps Warning, Boosted IMG_0145
RHeinz
Ric
Houston, TX
Your radiator is cooling your engine. The thermostat is installed to limit low engine temperatures. It has nothing to do with rejecting engine heat at high engine outputs.
Not saying OP is wrong or anything - he's clearing distinguishing between coolant and oil temps - but for some here there may be some confusion
I don't have a monitor hooked up so I can't see what Coolant temp is precisely, but I've never seen the coolant temp indicator budget from 4 bars (just short of middle of the gauge). I don't know of any built-in display on the IPC that shows what actual coolant temp is.
You can see oil temp in the Off Road section. That isn't the same thing as coolant temp though. My "normal" oil temp is anywhere from 195-225F, depending on how hard I'm pushing, what the HVAC system is doing, etc.
I could very well believe that a long haul at a steady 20psi boost could overwhelm the cooling system. May be time to consider manually downshifting or re-gearing lower to get to a lower boost value, holding at very near max boost for a sustained time is just gonna be hard on a lot of things there.
With that said, yeah, I could see a cooler T-stat holding the oil cooler down a bit longer, but I think if you are maxing out that 20psi boost thing indefinitely, you are gonna overwhelm that too - you need a bigger/more efficient oil cooler to go with it. All the T-stat is going to buy you is a bit more time before you get back up to just about the same temps you've been hitting - just a function of that oil cooler.
RaefordRider
Tim
Raeford, NC
2024 Black Diamond Bronco
20 lbs boost? Is that occurring in regular driving, or are you slamming the throttle racing other vehicles? I often have the dash display showing boost, and don't think my Bronco 2.3L has ever gone past 10 lbs boost, and in typical driving maybe hits 5 lbs occasionally if that.
I hit 18 the other day when I tromped on it. If I was doing regular loads with 20lbs of boost I'd move to a powerstroke...
B22-2023
B22-2023
Houston
I hear you. I’ve chased this in other loaded engines starting with of all things my Early Broncos - a lot of times it winds up being an oil cooler. I’ll start with thermostat as a cheap experiment. The Baxter / Mishimoto idea I have for oil is pricey and potentially a PITA to fit in. Your down shift comment is good, I forget that on these 10 speeds I have more to play with at high speeds; I don’t haul heavy enough to want to re gear although that would address the below loaded truck
issue.
And @RHeinz I hear you too; but though not ideal it’s not as bad as it looks, that bumper has more decent air passage to the intercooler and general ventilation not seen in that pic - especially at speed. And it’s a big intercooler with a good spec for heat rejection.
And as for the problem Iā€˜m trying to beat, it looks like weight - and the end of this camping trip I hit a CAT Scale on the way home - 7360 lbs. Grossed up for the extra food, water, gas cans, ice and and extra passenger who wasnā€˜t on the scale, I was at 7745 lbs fully loaded. I’ll weigh it empty this week after unloading.
