Hi all
mObridge
mObridge
Fraser
Orange County, California
BMW e92 328
This looks like a great option. I have pvr center, hertz dcx 100.3 for dash and dcx 165.3 for Mabbett pods All on order. Eventually a sub upgrade
Thanks! We also now have a proper RTA tune done for our amp with the Hertz dcx100.3 in the dash! We will have a tune library up on our website soon where this will be available along with lots of others!
widnere12
Georgia
Ok ill spill the beans on one, its a full plug and play amplifier kit for the B&O system that fits in the factory location!
I COULD HANDLE THIS!!!!
mObridge
mObridge
Fraser
BMW e92 328
Hossfire
Richmond, VA
'06 Jeep Commander
@mObridge I looked at your install document. So, does your solution not require pulling the dash apart? I watched a video on an Amp Pro install and they had to get access to Audio Control Module to fit a T-harness.
thenewjs
Archie
Braptor
No, just panel under the steering wheel and panel under the climate controls. If you don’t have small hands you may have to pull the thermostat
Draughon
Daylon
Dallas
BMW 4-Series
Here's a good video showing how to get to it. I have big hands and used a narrow panel popper to depress the tab on the plug and a pair of needle nose pliers to grab it and pull it out.
vicorjh
Jay
2023 Bronco Wildtrack
The t-harness essentially interposes 3 of the channels: center, rear left, rear right. All of the other channels are directly wired into the amp using the factory harness (assuming the amp location is in the stock location with upgraded/lux package).
An alternative to the t-harness is to wire directly from the amp for those channels. In that case, you'd have a two pairs running to the rears, one pair running to the center, along with the power harnessing from/to the amp. You'd need three speaker connectors or pigtails. One advantage is that the individual run lengths for those channels are cut in about half ... while avoiding a t-harness installed into a tight space. It is a little bit more work running those as you'd need to partially remove the trim along the brace, though.
mpeugeot
It’s not a difficult install.
Hossfire
Richmond, VA
'06 Jeep Commander
That makes sense. Thanks.
Migo
Roy
Houston, TX
www.instagram.com
I just completed the Mobridge install and have run into an issue. When I power on my Bronco the head unit powers up and I can see playback, but there is no volume. I can turn the knob/press the steering wheel button and the volume graphic comes up, but it will not turn past zero (0).
I have checked all connections and they are secure. The Mobridge Amp is getting power (red lights on) and the dip switches are set correctly per the instructions. I have also made sure the amp is running the latest firmware (it is) and the DSP program can interface with the amp just fine. I have also done a Sync reset (power + seek right).
Any ideas?? I have emailed Fraser @mObridge (who is awesome btw), but since it is the weekend, I thought I would check here as well.
Thanks!!
mObridge
mObridge
Fraser
BMW e92 328
Sounds like you may have missed the flat 4 pin connector that comes off the main harness and plugs into the back of our amp
Migo
Roy
Houston, TX
www.instagram.com
I have that plugged in as well. And now my head unit is powering off/on randomly and my blind spot sensor is giving an error.
mObridge
mObridge
Fraser
BMW e92 328
Email me lots of photos and I'll see what's going on
thenewjs
Archie
Braptor
Thanks!!
I made the same mistake. Yellow wire should be closest to the data cable.Its keyed but will plug in the wrong way.
Migo
Roy
Houston, TX
www.instagram.com
Swapping the blue and yellow wires worked like a champ.
Everything sounds great, except now I get no sound from driver dash speaker. Tried factory and new speaker and no sound. I tried with the Mobridge harness plugged in at the ACM, and the factory amp plugged in at the back, and then I got sound.
So close to being final!!!
