Help Needed For 37's
tip reedy
Illinois
Bronco 2024
I want to put 37's with 18's on my 2024 Wildtrak Sasquatch with Hoss Fox 3.0 suspension package. What do I need to do and still keep the Hoss Fox 3.0? Build pictures would be great! Thanks for all the input.
PJP
PJ
Canton, GA
Out of curiosity…you planning on a 12.50 or 13.50? I’m also in a ‘24 Wildtrak and considering 37s on 18s
Nanook
Jonathan
Raptor, Bronco, Galaxie, Ducati Streetfighter V4S
Zone kit above or Body Lift, JKS max tire kit, new wheels or wheel spacers, some plastic trimming, maybe side step removal/trimming (if applicable) or completely different side steps, and mud flap removal.
All combined should get you in and out of parking lots without rubbing. 🍻
  • Like
Reactions: PJP
Valhalla
Valhalla
Chattanooga Tn
Not a lot of tire options in 18s last time I looked.
PJP
PJ
Canton, GA
Yep that’s the problem. Very limited selection. I saw a Hennessy Bronco on 18s that looked good but they were on 35s
DoYouBronco
Lux Sponsor (Level 2)
Tyson
El Paso
hpbuilt.shop
You could run a perch collar lift or a spacer lift from zone. Some notes, a perch collar will stiffen the ride up a little bit and a spacer lift will not change the ride quality. The spacer will however increase your shocks extended and compressed length. A longer compressed length = more room for the tires when stuffed.
Next I would do the JKS tire clearance kit to get rid of the crash bar mounts.
If you want to learn more about different types of lifts or special forum pricing, shoot me a message….
Nanook
Jonathan
Wheel diameter is not your problem.
Clearing 37’s is your problem. It doesn’t matter if it’s a mall crawler or trail rig. 37’s are going to rub if you’re keeping the stock Fox shocks.
  • Like
Reactions: PJP
Oldhippie
Barry
Santa Cruz, Calif.
zone kit, 1” body lift, JKS kit, diff drop, and -18+ off set wheels….if keeping stock coilovers….but really with 4wp/procomp coilovers still available so cheap I would switch to them (sell Fox for near wash) and do above mods (Without the zone kit)…ya may get by with less but as long ya got it apart…
  • Like
Reactions: PJP
lewy
Kevin
PA
Close but not 18”
37x12.5 17 BFG MT
17” VR601BL Vorstein wheels
1/2 Body lift
Zone 2 in lift
Max tire clearance kit
Ford Bronco Help Needed For 37's IMG_4432
Ford Bronco Help Needed For 37's IMG_4433
BadlandsGrizzly
@lewy Beautiful rig! I’m interested in those ditch lights!
Link to the setup?
lewy
Kevin
PA
Mike leggiero
Ky
Ford Bronco Help Needed For 37's 1000000805
green is a base 2 in lift and 37s. the blue on is a 2 .5 lift and 37s .
Ford Bronco Help Needed For 37's 1000000804
