Gnarly tailgate rattle
HBTFD
Newnan GA
F350
Can you replicate the rattle by moving the tailgate by hand or only when driving?
Frangiepod
Angela
2021 Ford Bronco Badlands Sasquatch 4 dr
At around 300 miles in, my Bronco has developed a pretty gnarly rattle from the tailgate.
I will try to get a recording, but it is very loud and easily reproducible by driving basically any distance.
I had someone ride in the cargo area and they said it’s coming from within the tailgate itself, like metal pinging against metal. Not near hinges, latches, or where the tailgate interacts with the hard top window seal. I popped the accessory ready cover off on the inside of the tailgate and there are only some small holes into the interior of the tailgate, so no way to reach your hand in there or anything and it’s unclear how it could be disassembled any further, given it’s metal sandwiched together.
Ford dealership service departments around here aren’t rated well at all, and since they likely haven’t troubleshot many/any Broncos yet, I’m thinking about waiting and continuing to see if I can remediate before asking them to deal with it. Not sure how long I can go though, because it’s VERY loud!
Anyone with service manuals able to provide any insight? Is there better access from behind the spare tire? Not sure I would feel comfortable doing much more myself, but if there’s a quick and easy way in I may give it a shot..:
Ive got the same issue. Started pretty much right after i got it. Gonna try taking the tailgate access panel off to see what’s what.
NotApplicable
BEVs
The main one across the top has just tiny holes behind it in metal, not enough to see what’s going on in there.
I haven’t tried the plastic panel closer to the door latch though…
does yours sound like some sort of metal pinging on something else metal? I’m happy to hear I may not be alone (though sorry you’re part of the club)
Frangiepod
Angela
Yes it's a metal sound. Loud. Tick, tick, tick random not a pattern. Really annoying. I hate rattles. Hope we can get this figured out... Had someone ride in the back too and they said it was the tailgate passenger side.
Max1h
Max
www.instagram.com
23 Bronco Badlands, 1968 bronco, 23 bronco badlands number 2
if its A squeaky raddle could be the hinge/latch, my f150 tailgate started rattling was as simple as spraying wd40 into the latch.
NotApplicable
BEVs
Yes, toward the passenger side.
And you’re right, it’s so random. Sometimes I’m like “oh, these bumps in the road will trigger it” and then it doesn’t do it, but I’ll be on smooth ground and turn a bit and it will go off
Frangiepod
Angela
Doesn't sound like a squeak so much as a metal "ticking". I do hope it's as simple as some WD40 though!
NotApplicable
BEVs
Yes, my partner said it sounded as though something metal was suspended by a string bouncing off the exterior panels lol
JTK37
Joe
New Jersey
2016 VW Golf R
same issue for me and also started around 300miles. I did remove the plastic near the tail gate latch. There is a decent size cavity to clear the latch. But no sign of what could be rattling.
and I snapped one of the tabs off the back of the plastic cover. Probably going to make the rattle worse. Great. if anyone Know where I can find that part number lemme know
rdass623
ron
new orleans
Toyota Tacoma TRD Off Road, Fiat 124 Abarth
if it is a ticking sound, it may be gravel hitting the floor pan.. some vehicles in order to save weight don't use much sound deadening mats...
NotApplicable
BEVs
It’s not that
the sound has been unquestionably pinpointed to from within the tailgate, and not related to hinge or latch
Frangiepod
Angela
It’s not that
Agreed. Still no luck finding the source.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
It’s not that
Have you removed that plastic cover on the tailgate and driven around with it off? Sometimes plastic rubbing on stuff makes the most annoying sound. Curious if that entire piece is the issue.
This is driving me nuts, and it’s not even my vehicle. For the love of God, please take it to the dealership to get answers!!! :ROFLMAO:
Frangiepod
Angela
Not yet but that's next. Stay tuned.
