Global Window CLOSE issue with DDM
Gotcha, thanks. This might be a stupid question, but I’m assuming you can’t just enable the ui using ForScan and then enable the actual feature in the Sync 4 ui, right?
Nope. You can enable the feature without sync, but the other way won’t do anything
murrman
Sean
Toledo, OH
2024 2 Door Black Diamond
Just to give an update, I was able to get the remote up/down working. There’s also an option in the “easy mode” version of the APIM to enable the setting in the Sync 4 menu, so I was able to enable that without going into the as built section as well.
