Jdegid_SoCAL
Coto De Caza , CA
Tesla , Jeep Wrangler
I will be in, if and when @GearShade / @StickerFab can make a cover or there is a more finished looking solution will be Following
thattrue32
Erny
Fairfield CA
1932 Ford Pickup
Y'all asked for it, so here is our offering for a solution to use the hardtop and the mesh at the same time! Will work for the 4 Door and 2 Door! 😉
NOTICE: This will require drilling into two of your hardtop twist locks.
Installation is very easy. Basically, you will remove the 2 centermost twist locks and install our stainless steel plate add-on. The mesh will have two grommet holes for an 8mm T-handle Allen wrench to pass through. You will use the Allen wrench as a "key" to twist the locks to open and close.
Your top warranty is most likely void now. :eek:
Kit contents:
  • Left stainless plate
  • RIght stainless plate
  • 2x M4 nut and bolt set
*Long 8MM t-handle wrench will be available separately, still sourcing them....
Installation:
Time 10mins
-Remove front panels
-Remove twist lock from the panel with your Bronco OEM tool kit.
-Please plate over the twist lock (clamp it in place) and drill two 4mm (3/16") holes through the holes in the plate
-Install provided M4 nut and bolt through the plate into the handle
-Reinstall the twist lock into the panel
Operation:
Full instructions will be added to our site soon.
*Removal of the front center bungee and clips is necessary while the hardtop is on. When you remove the panels, reinstall the bungee and clips.
The remaining twist locks and latches will be accessible from the edge of the mesh.
This product will go live next week! Visit www.gearshade.com for updates.
If you already have a soft-top version, we will be making a kit to retrofit it. 😉
very cool!
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
@GearShade what is the forum discount code?
I want to pull the trigger...do you have the discount code yet? If not, will you adjust price accordingly if i place an order now?
GearShade
GearShade
William
'22 Big Bend, '19 JLU Rubi, '07 JKU Rubi, '04 F350
We have created a special discount code for members!
Use the code: BRONCO6G at check out and get 15% off for a limited time!
Bearcat1
Travis
2017 Expedition Limited, 2006 BMW 330xi
Thanks GearShade, just ordered with the discount code.
wyobronco
Clint
Wyoming
'21 Bronco Black Diamond 2 DR
2 DR Hardtop PLEASE :D
echance01
Chandler, Az
2019 Ram 1500
Thanks! Just placed my order. Appreciate the discount code.
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
@GearShade Do the color mesh tops have color matching binding/straps? or are all mesh tops made with the same black binding/straps.
Also, for the Hard Top, is the tool included or only the plate/hardware?
GearShade
GearShade
William
We only use black. So it is the same for all of them. This keeps costs down.
A 8mm wrench is not included. We are going to sell them, once they get here. But for now...
https://www.amazon.com/gp/product/B07WKVZGLM
zedster
Bill
Las Vegas
'21 Bronco 2 dr Badlands SAS, '22 F150 PowerBoost
GearShade
GearShade
William
How come you state this and the website says 4 door?
Most likely a typo ;)
Please let me know exactly where you see this.
