TheShark
Really clever, I might just have to order one.
4runner
4runner
Los Angeles
Ford Bronco Toyota 4 Runner
Does this shade also cut back on wind in the rear seats of the bronco with the top off/down ?
mC.242
2021 Big Bend 4dr (sold)
Perfect! Will be ordering one. Will the production version of the latch plates be painted?
GearShade
GearShade
William
'22 Big Bend, '19 JLU Rubi, '07 JKU Rubi, '04 F350
We will provide raw, slightly brushed stainless steel. End-user may paint or decal as they wish.
djp
djp
Idaho
'22 Badlands 4dr || '21 Bronco Sport BigBend
Bronco Don
Don
Rialto, California
Tacoma 4x4
I don’t understand I have theā€ best top ā€ mesh bibini and use it with my four door hard top all the time, no drilling holes, It fits under the hard top and when I want to take the top off it’s already there.
Strick
Peter
Malvern, pa
Grand Cherokee
Gear Shade…there’s money to be made in the Bronco MIC top business. Give it some thought…Ford continues to shit the bed!
De Brus
De Brus
Washington state
'14 HD 1200, '66 IH, '62 VW
I didn’t want to be the first to mention it, but I had the same thoughts. ☺ Why drilling the holes @GearShade ?
Techun
Pa
BD, 2.7, MIC, 4dr
Is that the one with all of the crazy zippers?
DFNMAN
Anthony
Tampa, FL
21' 2dr, 15' M3, 07' FJ, 03' M3, 79' 928
Wouldn't a zippered hole be easier than drilling the top?
Inc0gnet0
Phoenix
'12 Hon Pilot EXL, '16 Acura ILX, '20 Acura MDX
Y'all asked for it, so here is our offering for a solution to use the hardtop and the mesh at the same time! Will work for the 4 Door and 2 Door! šŸ˜‰
NOTICE: This will require drilling into two of your hardtop twist locks.
Installation is very easy. Basically, you will remove the 2 centermost twist locks and install our stainless steel plate add-on. The mesh will have two grommet holes for an 8mm T-handle Allen wrench to pass through. You will use the Allen wrench as a "key" to twist the locks to open and close.
Your top warranty is most likely void now. :eek:
Kit contents:
  • Left stainless plate
  • RIght stainless plate
  • 2x M4 nut and bolt set
*Long 8MM t-handle wrench will be available separately, still sourcing them....
Installation:
Time 10mins
-Remove front panels
-Remove twist lock from the panel with your Bronco OEM tool kit.
-Please plate over the twist lock (clamp it in place) and drill two 4mm (3/16") holes through the holes in the plate
-Install provided M4 nut and bolt through the plate into the handle
-Reinstall the twist lock into the panel
Operation:
Full instructions will be added to our site soon.
*Removal of the front center bungee and clips is necessary while the hardtop is on. When you remove the panels, reinstall the bungee and clips.
The remaining twist locks and latches will be accessible from the edge of the mesh.
This product will go live next week! Visit www.gearshade.com for updates.
If you already have a soft-top version, we will be making a kit to retrofit it. šŸ˜‰
Absolutely great solution! on the wish list most def.
Contact
Randy
Austin, Texas
Bronco Big Bend. FJ Cruiser
Interesting. I thought it was just for those that have the soft top. So, are there any modifications or any leaks when the hard top is on? Would you mind displaying a picture please? Thank you.
Update: I did see in the installation instructions that they do show how to attach it on a 4-door HT.
GearShade
GearShade
William
Our mesh top has several advantages over the OEM one. Our weave is a little tighter so that means less light gets to the top of your head. Our top lays tighter than the OEM version. Theirs has to be a little loose for all the "crazy zippers", so it can be easily zipped back up. We also offer custom digital printing, right on the mesh. Almost no limitations! A few years ago a lady ordered a custom print top for her jeep. She sent us an image to print. It was her dog, laying in the surf, at a beach at sunset.
We started with a version for the soft top Bronco. We had a TON of interest for a version for the hardtop, that could be used without removing the mesh to access the twist locks. So this is our solution.
Hope this helps. :)
Ford Bronco GearShade Mesh Top HARDTOP VERSION! 10_years
