Full-time 4x4 vs part-time
Goat4454
Northern Ontario
Audi
Big Boss
Outer Heaven
Bronco Big Bend
im getting base and advanced not available on base model for some reason
The reason is because it's the base model.
I am still shocked to see people complain about options not being on the base model. The base 2 door model exists so they can market the Bronco starting under 30K. Ford doesn't want you to buy the base, dealers don't want to sell the base. That's why certain options are locked to higher trims.
NCOBX
H2 Hummer, Holden Commodore
it’s - huge jump in expense for advanced. Huge.
I don’t see why it’s a big deal, this isn’t a full-size truck with a long wheel base and no weight over the rear. Auto 4wd introduces clutches to the transfer case... clutches wear out. I don’t believe realistically anyone’s missing out with the standard case.
Goat4454
Northern Ontario
Audi
I am still shocked to see people complain about options not being on the base model. The base 2 door model exists so they can market the Bronco starting under 30K. Ford doesn't want you to buy the base, dealers don't want to sell the base. That's why certain options are locked to higher trims.don’t be surprised or shocked. Probably the most common type of complaint when buying a vehicle.
don’t be too shocked. It’s common
BAUS67
redneck
Central PA
Yup.
Zero interest here in a gas hog full time 4wd.
Personally I would be thrilled with a lever for the 4wd...
Amen to that !!
I prefer ✌ !!!
Ford Bronco Full-time 4x4 vs part-time 1613526667466
KJR50
K
SoCal
I'm not telling U.
One good reason is that all wheel drive burns more gas as you are turning 4 wheels all the time.
imagine a Sasquatch bronco turning all four 35s all the time. Your mpg would be around 10.
AWD does not power 4 wheels all the time.
Most awd design today are so advanced, you think you’re driving fwd or rwd until you hit a slippery patch. Then black magic happens, power is cut to the wheel slipping & applied to the wheel with traction. Fuel economy is negligible.
85_Ranger4x4
Iowa
1985 Ford Ranger
My wife's Edge is part time AWD so you are driving a FWD most of the time.
Sampsonrustic
Sampson
SoCal
F150 4x4
Agree to disagree.
A4 is a proven convenience and safety capability that I personally have enjoyed having. My current f150 does not have it and there are plenty of times in inclement weather where I’m either Switching back and forth as I hit pavement and snow, or just leaving it in 2H to not accidentally leave it in 4H on a dry section of road, but wishing I was in 4x4. Leaving it in A4 is just really convenient day to day in snowy climates that aren’t 100% covered all season, and diverts power in a very smart and effective manner that’s beyond the capability of some standard 4x4 systems. It’s definitely not necessary for off roading, it’s really for inclement weather where you aren’t in consistent conditions.
Montana Bronco
Montana
Chevy
^^^^ THIS ^^^^
KANE COUNTY ILLINOIS
SAL
GMC YUKON
Without sasquatching it, you have to move up to at least a Black Diamond to get the advanced. I wasn't too happy about that either.
I'm in the same situation! I would love the Advance but it's not available on a non-sas-Big Bend.
85_Ranger4x4
Iowa
1985 Ford Ranger
Agree to disagree.
Also great for masking conditions.
It helps you go, not stop or steer.
The new stuff might be different but it badly needs a light or something to at least say "hey, its slick and you are in 4wd now"
The older Fords I have been around have nothing, they just do their own automatic thing.
I don't mind shifting mine manually.
Sampsonrustic
Sampson
SoCal
F150 4x4
Right I mean I’m assuming you actively are putting into that mode when you go driving in bad conditions, I’m not suggesting leaving it on 100% of the time.
Definitely agree it can make people feel more confident than they should.
stopping powwr
Raptor911
Raptor911
Broadlands, VA
True. Except that an all wheel drive system will never beat a 4-wheel drive system in terms of traction/grip. This is why real trucks have a 4-wheel drive system.
If you want AWD then go buy a Subaru.
BTW ... The Bronco has exactly what you are describing >> Advanced 4x4 with Automatic On Demand Engagement >> 4A
Ford Bronco Full-time 4x4 vs part-time 1613538870972
