Full Range to rear speakers
SASQTCH
Justin
Oklahoma City, OK
Are there any plug-and-play replacement speakers? I would be fine replacing the speakers, but something about cutting wires in a brand new car really freaks me out.
if you don't want to cut and splice you can easily twist the end of the wire to make it tight then stick it into the wire harness hole that matches the + or - side. Then use electrical tape to hold them in place. See a few people do this.
SASQTCH
Justin
Oklahoma City, OK
This is why I asked Urbanranger94 if he had stock speakers still. I believe the stock speakers have filters on them as well as the software limiting output. The sound bar flash removes the software problem but the hardware filters remain.
I think there is a filter on them, and it's the rear enclosure that's adding to the problem. I will say there is no visual difference between them and the front speakers once out of the vehicle though.
SASQTCH
Justin
Oklahoma City, OK
On the back of the stock speakers (below the part number) is M5XUN and when you Google that the first hit is "Ford Fiesta high frequency speaker". All 4 speakers front and rear are the same.
Ksjrb03
Tx
F250
I can confirm the B&O system gets these same great Fiesta speakers in the rear pods.......
5280Bronco
Denver
BrentC
Brent
Calgary, AB
2019 F150 Sport, 2021 Bronco Badlands
Well, with speakers it’s not as freaky as…
Ford Bronco Full Range to rear speakers 2B760E18-E8BF-420D-BD0A-3CC51339DD8E
Jgoodwin
18 ram 2500 diesel
I made adapters. I think you can buy them now too but I have purchased the connectors and pins a while back. I still haven't installed my speakers yet. Was hoping to tackle it this weekend
What are the connectors called. I don't mind making my own. Thank you.
j_anderson
Jason
Fort Wayne, IN
www.instagram.com
I bought the connectors and pins from Mouser Electronics. Id recommend ordering several extra pins. They can be messed up pretty easy so having extra on hand is good idea.
I bought these wires from Amazon. The Infinity ref speakers that I bought didnt include pigtails. So, I needed those terminals anyway
Ford Bronco Full Range to rear speakers Screen Shot 2022-02-16 at 9.37.10 PM
da_jokker
Jeep Wrangler JKUR
Sounds like you need the JBL flash and get rid of the blockers (via speaker replacements)
But now it begs the question, for all the people that tweaked Forscan and didn't see a difference.... Was it also because they had stock rears?
Any of you guys replace your rear speakers and then try the Forscan trick?
j_anderson
Jason
Fort Wayne, IN
www.instagram.com
agree. curious to know
pfbz
CO
F150 Turbo, 991 Turbo S, 996 turbo, Q5 Turbo
Those look great!
I didn't have the patience to order the connectors from Mouser, but rummaging through my connector box I found some Molex KK series 3-pin header strips (middle pin is unused) that were a perfect match for the pin alignment on the factory connectors, but without the shell.
I soldered up some pigtails to them, a few bits of shrink-wrap, and crimped on spade connectors for the speaker end. They slide into the factory connectors with a super-snug fit. They are designed to just be friction lock, there is no chance they are ever vibrating out, but you could always throw a piece of tape over the pair to lock them in place as well. Zero cutting, 100% reversible, less than a couple of bucks to make a pair.
Also, the stock speakers *definitely* have a high-pass capacitor filter built into them. I can't see any value printed on the cap without getting destructive, (which would tell us their crossover frequency) but it would be interesting to see what the value is, and if it is different dash to rear speakers.
Here's my pigtails:
Ford Bronco Full Range to rear speakers Bronco speaker mod - 4
Ford Bronco Full Range to rear speakers Bronco speaker mod - 5
Ford Bronco Full Range to rear speakers Bronco speaker mod - 6
j_anderson
Jason
Fort Wayne, IN
www.instagram.com
Those look great!
Here's my pigtails:
nice work man! I would have never thought about adapters like that but they will surely work perfectly!
Headsong
Ack, now I'm pushed to a 22....so without re-reading all 20 pages, does the flash still work for 22 or is it unnecessary? I recall reading that the Forscan doesn't work on 22's....
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
Yes, I replaced stock rears and did the FORScan mod and I found it definitely made a difference, especially at lower volume levels.
I recorded the before and after audio so you can listen for yourself, see my post on this linked here.
