Full Range to rear speakers
RedHotLava
Red
DC
2005 Nissan Xterra
Survey says........................................................F YEA!
Works, have caps on rear speakers and can tell there's more range and db. Did not need bar in vehicle or anything disconnected. Took about 10 min after hooked up to do the file install.
Awesome, thank you for that. I'm definitely going to ask them to do it before I come to get it, if/when it ever comes.
Headsong
Just notified the dealer to do this when it comes...if it comes.
Tank
Boone NC
18 F150, 18 4runner, couple of old Datsuns
Let me check on our FE next week. If it shows up in FDRS for that VIN, it should. My gut tells me no.
Thanks, that’s what I was thinking too. Appreciate you checking!
Ksjrb03
Tx
F250
This is great for those with the base system, but I highly doubt this will work with the B&O unfortunately.
  • Like
Reactions: Cat
wcmaness
wcmaness
Wesly
Arlington, TX
'21 Bronco OBX; '11 Armada; '02 Tahoe Z71; '91 XJ6
So - with this fix understood, that clears the way for an aftermarket oversized rear speaker pod to be produced.
Headsong
Or just better speakers.
RyanP
Ryan
Maryland
Mazda CX-9
My Bronco is (hopefully) coming in next month. I am sending an email to my dealer now to see if they will flash my bronco without the JBL on purchase.
Good call. I'm doing the same thing. hopefully they accommodate without issue.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Right after I took the 600hz blockers out 🤦‍♂️
So, with that flashed - do the 4” speakers act the same as the dash speakers?
This is what I was trying to achieve when I asked for the instructions a few months ago - but, realized it was a different program and Forscan wasn’t an option.
soupcook
Walt
2020 Ford Ranger and 2017 GMC Acadia Denali
It can be done.
I buckled down and bought the sound bar that Ford is pushing (the JBL BB4000). It looks to be plug-n-play out of the box, because it uses the same connectors as the factory rear speakers. But, once you buy it, the installation instructions tell you to take it to the dealer after installing, so that the computer can be "flashed" to accept the sound bar.
I connected it up anyway without flashing it, and it sounded just like the factory rear speakers - high end unimpressive sound. I then took it to the dealer who "flashed" it for free. Then it performed like you would expect the sound bar to sound - full range and full of great sound.
Curious about this "flashing" business - just for kicks - I unplugged the sound bar and plugged back in the factory speakers I had removed - and viola - full sound range from the little factory speaker pods.
I don't know why it comes from the factory with limited rear speakers that way - but clearly it is intentionally limited.
To "flash" the audio, the sound bar instructions say you must have the FDRS software ACM (audio control module) to perform the "Audio Front Control
Module (ACM) Software Update." The trick then is - find out how to do that (or get the dealer to do the flash) without buying the sound bar.
The good thing is that I was able to tap into the rear speakers (instead of running wires all the way up to the front kick panel speakers) to add my subwoofer.
With the sound bar I've got the range all around and with a sub I'm done.
STILL - I wonder if I would have needed the sound bar if I could just broaden the range of the rear speaker pods.
Anyway - if this hasn't been posted before (I didn't find it - sorry if this is a repeat)- there's the answer.
I received my 2022 OBX Lux last week. I read the entire manual and in the section for settings on the stereo, it was default to Stereo and Surround was a second option. I changed to Surround. It was a huge change in the B&O system sound. Maybe check that you are in Surround?
Ford Bronco Full Range to rear speakers 2022 OBX LUX Sound Screen
Broncola
Hawaii
Element, ‘75 Bronco widow
How much will a speedo/audio system recalibration combo cost at the typical dealership? 🤷🏽‍♂️💵💰💵
2Jeeps&PatriotX1
Denver, CO
Had it in surround since it left the dealership. 3k miles later…the B&O system still sucks. This coming from my wife who is not the one in our household who typically upgrades audio in vehicles.
2Jeeps&PatriotX1
Denver, CO
Here I was getting excited after flip got it to work to only find out it wasn’t the B&O system.
Dirtyjed
Orangevale
05 Dmax, 86 FunRunnah, Tiyoda truggy, Honda shi
Fuckinehtweetybaldeagleawesimrness
flip
Phil
IN
www.ruxerparts.com
Fords
I’m not going to speak for other dealers but FDRS can get cranky, files from Ford don’t download right and various other things can happen. On mine, Marlin hooked up, did another update for chassis control module and sound bar update in about 45 min. Now, we’ve done telematics control unit updates on other vehicles that have taken 4 hours due to the file sizes. We’re on fiber at work and have stupid good access points so we aren’t the choke point.
I would think a dealer could easily do just the sound bar in an hour. If it’s in for some other software or work and they have a reason to have FDRS hooked up they might charge less. All depends on your dealer and if they are as awesome as us. :p
