timhood
Tim
Several
The MPG people brag about on this site continues to baffle me. I wish I lived on the planet you guys seem to live on. I have a 2.7 Auto 4 door Heritage and I have put 93 octane in it from the very beginning. I have never broken 17 mpg on any tank of gas.
No matter what mode whether it be normal or Sport, normal traffic or highway, I have never seen anything over 16.5 MPG. Ever.
I know the larger tires of the Heritage/Sasquatch make a difference, but I feel like you should be able to do a little better than that. I have the V6 Badlands, albeit, non-Sas and 2-door, but 18 is doable without any effort--on 87 octane. Above 20 is easy if I drive 70 instead of 80 or higher.
My Bronco passed 20K while off-roading recently. I was averaging over 18 with 2/3 off-roading and 1/3, 70+ mph highways on 87. Do you drive really fast or get a lot of headwinds?
Ford Bronco Fuel Milage MPG Gains from Ford ProCal Performance Tune IMG_5378
I think a lot of people get hung up on Bronco A gets X MPG, while Bronco B gets Y MPG
There's a ton of factors besides the tune that go into what mileage you get. SO don't get hung up in the absolute MPG numbers... or the fact that one guy gets better, or worse mileage than someone else.
The point of this thread, was that Bronco A got X MPG before the tune, and then Y MPG after the tune - which nails it down to just one variable (hopefully, unless other stuff changed there). That's a valid observation. You do expect MPG to change somewhat with a performance tune - just usually I would expect it to be downward. In this case, a lot of people, including myself, are seeing the opposite.
Which is good - better performance, better milage - what's not to like: Having to run Premium gas (also, Ford ninja-removing features).
Acadist
WA
2023 BadSquatch
Only when I keep my foot off the pedal, lol
Hatman
Argyle, Texas
Badlands Sasquatch 2.7L
22 Badlands Sasquatch 2.7L. I used to get 18-19 MPG but the factory calibration on the speedometer was off to actual speed. After I calibrated the speedometer to the correct values, my MPG dropped to 16. Numbers aren't always as they seem.
Syringe
Cam
Laramie, WY
'16 ZX-10R, '21 Z H2 SE, '13 911
Got an improvement of ~2 mpg after the tune on my 2 dr. Badlands, with the manual. There was a real improvement while towing, too.
lat2801
NM
2024 Bronco
I travel a bunch so I find myself in 87 or 89 only pumps. How will this affect the pro cal? Only thing that's holding me back
91Blue
Lake Orion, MI
2022 Ford Bronco and 2022 Ford Bronco Sport
Base sasquatch 2.7 auto 19.5 avg on regular gas. An I thought that was bad mileage!
Happy New Year @freebob …. Just reading this thread to gain some insights on fuel economy. I currently have a 2022 Outer Banks with V6 but no Sasquatch. I am looking at a low mileage 2023 Outer Banks with V6 & Sasquatch & I am wondering how big of a hit on Fuel Economy comes with the Sasquatch. I currently get 22.3 to 23.5 mpg regularly on my daily commute of 50 miles round trip. My Outer Banks is the daily driver Bronco & I have been very pleased with MPG & performance. I see your comment that you get 19.5….are those stop-n-go conditions or favorable driving conditions. My commute is 50 to 60 mph with only a few stops.
Thank you.
Tacnav#1
Gene
Gulfport, MS
Bronco Badlands, F-150, Dodge Challenger R/T
I purchased the Performance Tune for my 22 Base Manual a while back. I’ve been very happy with it with it overall and noticed my average MPG has gone up. The first pic is from December 23 when I went from Denver to Wichita and back. The second is after the tune and several trips between Denver and Colorado Springs. Almost exclusively highway driving. Is anyone else seeing these kind of results?
Dec 23 = 14.9
Oct 24 = 19.8
I'm getting similiar mpg after I did the tune as long as I keep it around 77 mph. Badlands sasquatch.
JT58Bronc
JT
Fl
It would be interesting to see what mods really do yield better MPG. Tune, intake, exhaust, etc. I am all in to get the best MPG I can possibly get and invest now while I am still working before I retire- when every single MPG will count to get me to the fishing spot as cheap as possible. The problem with mods is that if they do yield more performance, we tend to use it and get the same if not worse MPG. I would think, tune, intake and exhaust should yield an improvement. I just added exhaust. I feel the increase and better breathing but still monitoring if there is any improvement.
FortMacGuy
Fort McMurray
2024 Bronco
We bought a 2024 Badlands Sasquatch Edition in October and quickly figured out the rig is no sipper. Our Bronco is a 2 door 2.7L on 35's.
87 octane gas yielded horrific 13.7 MPG (US gallon).
91 octane gas got us 17 MPG.
I've been wondering if the Ford performance tune will help fuel consumption since we already run 91 octane. Also really interested if there is any real world data for the best mods (intake, exhaust, etc.). I'm going to upgrade where it makes sense, otherwise it's a TurboSmart BOV and a somewhat lighter foot when I care about MPG's.
JL8jeff
Ewing, NJ
It takes a little time for the engine break in and then the mpg will go up. But we're in the middle of winter gas right now and that always puts a 1-2 mpg hit on most vehicles. I just did the tune around the end of Nov so I won't get a good mpg comparison reading until May most likely. I would give it some time but the biggest thing I noticed was when I added a 3" cat-back exhaust, when you took your foot off the gas, you could feel the truck kept coasting much better due to reduced backpressure I guess. The stock muffler is pretty bad.
donnyronny
donny
Canada
2023 Ford Bronco 2.3L, 2004 Dodge Dakota 4.7L
Dec 23 = 14.9
Oct 24 = 19.8
Im thinking about the Tune for my Base w/no sas. Howd the change in preformance feel when you punch it compared to stock?
23OBX2.7
AB Canada
2023 Bronco
JL8jeff
Ewing, NJ
Now that I've had a good 10 months with the tune, I wanted to go back and see what the results were. It's tough for me to do an apples to apples comparison because I did the intercooler, charge pipes, intake, lift and went to 37's all in a short window. But looking at my summer driving comparing 24 to 25, my mpg is pretty much the same (May-Sep) and came out to 19 mpg. But if you factor in that I did not need to recalibrate the speedometer for the 37's (the stock reading with 35's was always high) I'm actually getting around 1 mpg better mileage with the tune, the other mods and the taller tires. I'm a bit surprised and happy with the overall results.
Ford Bronco Fuel Milage MPG Gains from Ford ProCal Performance Tune mybronco_37boat1
thegoatman
NNJ
bronco
Just my $0.02, I would prioritize telling the computer the true tire size and having the Speedo behave like stock than getting true mph on it . Get the rev off tirerack and drop that number plus 1 in the livernois and try it..
I bet youll get even better results especially with shift scheduling, pulling that boat, and dealing with the hills in NJ!
I would say it’s easy enough to be worth a try
