Ford Performance Tune (Gearing)
MrGreen55
Kyle
Oregon
toyota scion xb
Has anyone tired this with the PERFORMANCE CALIBRATION? I saw they add this was wounding does it tune the bronco to the gearing like shift points and other stuff?
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
Yes, the tune has a dramatic impact on the automatic transmission for the better. In fact, I would buy it for that alone but I certainly am also enjoying the extra horsepower on the 2.7L. Previously I would go to sport mode an then put the Bronco back in 2H. Now I just leave it in normal all of the time.
MrGreen55
MrGreen55
Kyle
Oregon
toyota scion xb
:unsure: I'm not talking about the regular function of the tune I was talking about this
Ability to change axle ratio/FDU up to 5.38
unless you are talking about this?
F-Spot
SoCal
Tesla, FJ
The ProCal Tuner that comes with the Ford Performance Tune, will allow you to adjust the gear ratio settings. You still need to buy and install the physical gear set.
JediMcMuffin
Tommy
I'm saying that when you apply the tune, it dramatically changes the way the AT shifts. You can use the device to change the gear ratio if you swap out your gearing, but it doesn't give you access to change the shift schedule.
