Front leaning to the driver side
unfortunate
NA
I have a Sasquatch bronco with the 2.7 v6. I’m wondering if anyone have measured both front fender height on their Bronco? I was looking at doing a leveling kit as the next mod and noticed that my driver side front is 1/2 inch lower than the passenger side? The rears matches though…which is odd.
rtaylor
R
ID
19Raptor, 22Bronco
Some lean is within spec (0.3"). Not measured at fender. Note full gas tank. Also, be sure you are in 2H and pulled straight into level area before measuring.
Ford Bronco Front leaning to the driver side 1658812204401
Measured here (#2 - #3 on each side).
Ford Bronco Front leaning to the driver side 1658812258230
Ford Bronco Front leaning to the driver side 1658812279246
unfortunate
unfortunate
NA
Thanks! Did the measurements from there. I’m within spec. Though I’m nearly empty. I’ll check again when I get a tank of gas.
Silver-Bolt
Eureka, MT
You wouldn't be the first person here to have a random shock failure. Climb underneath.
Shocks do not support weight. The springs do. A failed shock has no bearing on the ride height.
fiatlux
CA
Volvo V60 T8 Polestar Engineered
OP did you end up getting any resolution to this issue?
unfortunate
unfortunate
NA
No resolution… I did the measurements someone posted above and it was within spec
CaptSolo
Tennessee
03 Jeep wrangler
My new (delivered this June) 2026 Sasq. Bronco Big Bend caught my eye when I backed it into the garage next to my Bronco sport. The body of the Bronco was leaning noticeably toward the drivers side, and the front bumper had less gap between the front of the body at the bumper end on the drivers side compared to the passenger side end. After measuring the rear bumper gap, it has the same relationship--more space between the body and the bumper end on the passenger side, less on the drivers side. I measured the distance between the floor and the top of the wheel well arches, and both driver side wheel arches were a little more than 3/4 inches closer to the ground (lower) than on the passenger side. I verified the floor was level with a long level. I then put an inclinometer on one of the straight frame crossmembers, and it was dead level with the floor. All these measurements cause me to believe that the body is mounted to the frame with a driver side lean. I left the Bronco at the dealership service dept. yesterday for a "full driver side lean" defect. I believe they will find the ride height to be level side to side because I measured the frame level with the floor, which seems to preclude any suspension issues being the cause of the lean. Of couse I got some 'deer in the headlights" reaction when I first described the issue, and one attempt at "driveability concern" verbiage to get me to leave. Unfortunately, this ain't my first rodeo. I hope the dealership will honor my warranty and correctly fix the issue. The only way to way to find out is to give them the opportunity to try.
Valhalla
Valhalla
Chattanooga Tn
Stick your jump landings to the other side for a while, it should straighten out from there.
Bindul
This is called the gas tank lean, It happens because of weight from the driver seat, fuel tank, and transfer case placed on that side.
