Front leaning to the driver side
unfortunate
NA
I have a Sasquatch bronco with the 2.7 v6. I’m wondering if anyone have measured both front fender height on their Bronco? I was looking at doing a leveling kit as the next mod and noticed that my driver side front is 1/2 inch lower than the passenger side? The rears matches though…which is odd.
rtaylor
R
ID
19Raptor, 22Bronco
Some lean is within spec (0.3"). Not measured at fender. Note full gas tank. Also, be sure you are in 2H and pulled straight into level area before measuring.
Ford Bronco Front leaning to the driver side 1658812204401
Measured here (#2 - #3 on each side).
Ford Bronco Front leaning to the driver side 1658812258230
Ford Bronco Front leaning to the driver side 1658812279246
unfortunate
unfortunate
NA
Thanks! Did the measurements from there. I’m within spec. Though I’m nearly empty. I’ll check again when I get a tank of gas.
Silver-Bolt
Eureka, MT
You wouldn't be the first person here to have a random shock failure. Climb underneath.
Shocks do not support weight. The springs do. A failed shock has no bearing on the ride height.
fiatlux
CA
Volvo V60 T8 Polestar Engineered
OP did you end up getting any resolution to this issue?
unfortunate
unfortunate
NA
No resolution… I did the measurements someone posted above and it was within spec
Valhalla
Valhalla
Chattanooga Tn
Stick your jump landings to the other side for a while, it should straighten out from there.
CaptSolo
Tennessee
03 Jeep wrangler
This is called the gas tank lean, It happens because of weight from the driver seat, fuel tank, and transfer case placed on that side.
The gas tanks on my '24 Outer Banks and my '26 Big Bend (both four-door bodies) are located on the right inside frame.
Neps
Floating off California
MX-5 30th, Focus EV, F150, Scout II (2)
I was hanging out with a mechanic friend and he gets a call from a woman who says "my car is leaning towards the drivers side", he tells her to stop by the shop.
About 30 minutes later a car pulls up and we watch as a 350LB + lady gets out of a Honda Pilot. Sometimes the problem is self-evident :)
Not saying anything about the OP, just an observation.
Valhalla
Valhalla
Chattanooga Tn
We were all thinking it 🤷‍♂️
