Front leaning to the driver side
unfortunate
NA
I have a Sasquatch bronco with the 2.7 v6. I’m wondering if anyone have measured both front fender height on their Bronco? I was looking at doing a leveling kit as the next mod and noticed that my driver side front is 1/2 inch lower than the passenger side? The rears matches though…which is odd.
rtaylor
R
ID
19Raptor, 22Bronco
Some lean is within spec (0.3"). Not measured at fender. Note full gas tank. Also, be sure you are in 2H and pulled straight into level area before measuring.
Ford Bronco Front leaning to the driver side 1658812204401
Measured here (#2 - #3 on each side).
Ford Bronco Front leaning to the driver side 1658812258230
Ford Bronco Front leaning to the driver side 1658812279246
unfortunate
unfortunate
NA
Thanks! Did the measurements from there. I’m within spec. Though I’m nearly empty. I’ll check again when I get a tank of gas.
Silver-Bolt
Eureka, MT
You wouldn't be the first person here to have a random shock failure. Climb underneath.
Shocks do not support weight. The springs do. A failed shock has no bearing on the ride height.
fiatlux
CA
Volvo V60 T8 Polestar Engineered
OP did you end up getting any resolution to this issue?
unfortunate
unfortunate
NA
No resolution… I did the measurements someone posted above and it was within spec
