Foutz Billet UCA question...
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
I just got my UCAs from Foutz and I'm not sure if this bushing is right or not. I've never installed a set and want to make sure this isn't something I need to address before install. Thoughts on how this bushing is sitting? The bushing on the other arm doesn't sit the same way.
Ford Bronco Foutz Billet UCA question... 20231103_092050
Ford Bronco Foutz Billet UCA question... 20231103_092216
Sjortiz
Shailyn
Dominican Republic
Bronco badlands Sasquatch
Not a bushin at all, that's an unival pivot, let's say thats the current tech we using, greaseless unival pivots, they do wonders for ride quality and articulation
  • Like
Reactions: Dom
BAUS67
redneck
Central PA
That part moves. As the others said, pivot for the uniball.
Word of caution>>>>>> Make sure the assembly is torqued properly. And checked regularly.
It won't be good if it comes apart.;)
https://www.bronco6g.com/forum/threads/angel-on-my-shoulder-les-schwab-fabtech-3-lift-fail.42614/
  • Like
Reactions: Dom
Dom
Dom
Dom
Phoenix AZ
Thanks fellas! I had a feeling it was ok, but needed to make sure since it wasn't a cheap investment. Also good to know about checking after its been torqued.
BigMeatsBronco
Allan
2021 FE 2 door
make sure you put the misalignment spacers in their proper position and orientation
