Foutz 2.5 Collar Lift Question
2021FordBronco2
Jo
Nampa, ID
2024 Ford Bronco Big Bend
I was curious if I needed new UCA with the 2.5 inch collar lifts from Foutz Motorsport? I bought some Hoss 3.0 takeoffs with them pre installed so I would like to know before I put them on my non SAS BB.
2021FordBronco2
2021FordBronco2
Jo
Nampa, ID
You might be able to get away without it but you should strongly consider it
Also rear trac bar relocation bracket
I will look into it, thank you!
adamruiz2001
SoCal
Ford SVT Lightning
Canyon Coolers
Flagstaff
canyoncoolers.com
73 Bronco, Dodge 2500, Sprinter Van
If you can properly align the vehicle your OK to go, but your are at the limit of what the stock UCA can handle. (Foutz makes some nice UCA's too)
2021FordBronco2
2021FordBronco2
Jo
Nampa, ID
Would you say it would be ok to off-road with the stock UCA or would it cause issues?
Mostly it’s just about getting the alignment correct
Canyon Coolers
Flagstaff
canyoncoolers.com
As I understand it a UCA isn't subject to a ton of stress with 'normal' driving. I think an upgrade is cheap insurance, and it doesnt add a ton of labor if your doing the shocks and coil springs, but no its not totally necessary. Accutune, Icon and Metal Cloak all offer reasonably priced ones too.
2021FordBronco2
2021FordBronco2
Jo
Nampa, ID
