Sooner
Ted
Henryetta, Ok
69 F100, 56 CJ5, 11 F250, 17 F150
I did the amber DRL mod but every time I start the bronco it defaults to auto for the headlight switch position. Is there a way to remember last setting if I wanted to leave all lights off?
Yes, it’s in the spreadsheet
  • Like
Reactions: Fly
JIMG
Jimbo
2023 Bronco
When on their site I searched for 2021+ Bronco accessories and got two hits under Electronics.
One is by Autostop Eliminator...
https://www.stickerfab.com/products...-maverick-20-21-escape?variant=40703665930351
And the other is by 4D Tech...
https://www.stickerfab.com/products...emory-2021-2023-bronco?variant=45905653072191
For everyones' info they also sell a plug-in Double Honk Eliminator and a Bambi Mode plug in, both by 4D Tech.
I used the first one Autostop Eliminator
on my 2022 BL High package 4 door 2.7 auto and it works great
JIMG
Jimbo
2023 Bronco
Corrected 2023 BL High package 4 door 2.7 auto
Squatchit
Corey
2015 Ram 3500, 2020 R1250GS, 2006 Volvo V50 T5
amccue90
amccue90
Andrew
Illinois
2021 Badlands
@amccue90
Will you be updating the spreadsheet with Lane Centering and intelligent cruise now that some have successfully completed the update?
I really appreciate the work you have done to keep everything in one place. It simplifies the process a ton and great to have on hand.
https://www.bronco6g.com/forum/thre...tive-cruise-control-and-lane-centering.71121/
If it's confirmed working by many sources, request editor rights from me on the sheet and you'll be able to update yourself
Mgrahammm
Mack
Newmarket On
2023 Bronco OB
Hey Folks,
I tried the auto start remove key in the spreadsheet and it didn’t work. Very familiar with forscan so I’m not thinking it was user error. Anyone else have a code that worked for them?
cheers,
FleshTuxedo
A
PA
'22 OBX 2dr.
Uhhh. Am I an idiot (don't answer that)? I Can't find the Amber DRL codes in the spreadsheet.
Edit: Nevermind, I think I read it wrong. Does the Amber DRL not work at night? Only daytime?
Arokcrwlr
Kraig
US - Alabama
2014 F150, 2014 Focus, 1973 Bronco
Correct, when the headlights turn on, the amber turns off
FleshTuxedo
A
PA
'22 OBX 2dr.
Thanks! Doing my Forscan mods this weekend and am just getting everything ready
swamp2
Seems like an odd one here... I changed the codes for Global windows open/close (i.e. hold fob keys for all windows down or up). All down works great but the all up fob press/combo only rolls up only the drivers side, not passenger. I suppose I should go back and double check that long list of needed changes have been correctly accomplished. Maybe someone has seen this or knows it's from one or more missing changes in Forscan? TIA!
Bronc’n Bronco
Kevin
Washington State
2023 Bronco
It’s been nearly a year since I did mine. I did the same thing. Went back in and did each door module as I recall.
Atro
Lars
Germany
´23 Bronco 4dr
I did "double honk, sport mode, chimes, seatbelts" without any problems. Perfect!
But the turn signal noise and auto hold do not work for me.
I also found the HVAC "auto hold switch on/off" and turned "on" but this also do not let the switch appear in the settings.
Cux211
NE PA
19 ram 2500 Laramie blackout cummins
Same here on my 24 badlands, added sport mode, killed double honk and seatbelt chimes couldn’t find the turn signal volume on the 24 though and from what I’ve heard you can’t kill the auto start stop on these new ones
derichio02
Bo
Southern California
Bronco Raptor, Bronco Wildtrak, Maverick, Tesla M3
Seems like and odd one here... I changed the codes for Global windows open/close (i.e. hold fob keys for all windows down or up). All down works great but the all up fob press/combo only rolls up only the drivers side, not passenger. I suppose I should go back and double check that long list of needed changes have been correctly accomplished. Maybe someone has seen this or knows it's from one or more missing changes Forscan changes? TIA!
Did you check if you did it for each door? It will number the doors 1-4 you have to enable them all. Haven’t done this yet on my 24 but did on my 22 and 23.
Gotchaa
Los Angeles
Tesla
anyone know how to disable the DSP check, if you have replaced your AMP with an after market it is not recognized and the ACM will throw a code, I would like to disable that.
